Power steering Hose replacement
Old Mar 28, 2021
Eemar's Avatar
Eemar is an unknown quantity at this point
Hello,
I am complete auto newbie!
But I got my civic since 2007 and want to fix this issue.
My civic leaked while driving, from the symptoms and through forums here i realized it was power steering fluid. I visually followed hoses but could not find leak. Then got underneath car and noticed this.
Again I dont know much but from web I found that this may be the return line, please correct.
On the picture at arrow, this line is touching exhaust. There is bit of flat on tube where it touches exhaust, I believe this is my leak! Now what I can think is that there is clamp that was holding this line to somewhere but that bolt or screw has either broken off or one of my mechanic forgot to attach in past or etc etc.
NOW I need help from wizards here , How do I replace this line and install new? Is it something doable for not so auto person? Q.2 -where do I bolt that clamp again so that line stays in place and not touch exhaust again.
Than you Everyone!
Old Mar 29, 2021
BrotatoChip's Avatar
Super Moderator
Re: Power steering Hose replacement
That is actually your power steering feed hose, part number 53713-SNA-A06. Nice work on doing some troubleshooting before coming to the forums though, we all appreciate that! From the looks of it I definitely wouldn't say that's an easy fix, going to take some work to get the hose out. If you don't have much experience working on cars I would recommend taking it to a shop.
Here is all I could come up with showing where that bracket is supposed to bolt, hopefully that's enough to go on. It would be the bolt/bracket on the right (labeled A).
niemand
Suspension
Mar 22, 2021 01:14 PM
teezyyoxo
May 4, 2017 10:36 PM
Sailorman3
Nov 10, 2013 11:27 AM
CivicSedan1998
Oct 3, 2013 07:52 PM
bobsagator
Suspension DIY
33
Sep 21, 2012 01:00 AM
