Steering looser after new shocks
Old Dec 12, 2018
Aerose91's Avatar
Aerose91 is an unknown quantity at this point
I have an 06 EX coupe and i just put new KYB shocks in the rear, nothing else. I didn't touch the springs and haven't done the fronts yet. With just the new rear shocks the steering feels looser. It makes me a little nervous about what it will feel like after the fronts are on. Is there a way to adjust the steering rack on 8th gen civics? What could cause this
Old Dec 12, 2018
GolNat's Avatar
Prelude Owner
Re: Steering looser after new shocks
Is the loose feeling coming from the front or is the back end wanting to swing out making the car feel unstable or loose?
Old Dec 13, 2018
after doing the fronts, likely best bet is to align it.
Old Dec 13, 2018
Aerose91's Avatar
The back feels pretty solid. I even rotated the tires and adjusted the tow a little in the rear to be safe. It just feels like the steering wheel has more play before it actually turns the car now
Old Dec 13, 2018
any changes in ride height? Rear lower? higher?
Old Dec 13, 2018
Aerose91's Avatar
It's ever so slightly higher. .25-.5 inch I'd say
Old Dec 14, 2018
if that is unstable, take to a shop.
hard to diagnose just by words.
did you adjust the tire pressures?
Old Dec 14, 2018
mac25's Avatar
Dr Krieger of Modification
Is it possible that you tightened the top mount bolts while the car was in the air?
if so double check to see if all of the bolts are fully torqued now that it's on the ground.
Old Dec 14, 2018
Aerose91's Avatar
I tried to pre load the suspension before tightening but i thought about loosening them then re-tightening now that it's on the ground. Could that alone do it?
Old Dec 14, 2018
mac25's Avatar
Should be fine as long as the top mount nuts are tight.
Once I tightened my front top mount nuts while the car was up. I basically just torqued the tension of the spring and thought it was fully bolted down. I only found out they where loose by 1/16 of an inch once I was driving.
When the vehicle weight pushed the springs down, I could see the gap.
Old Dec 14, 2018
GolNat's Avatar
Prelude Owner
Did you break an end link on the front sway bar? Without the front sway bar connected the steering could feel looser.
Old Dec 15, 2018
Aerose91's Avatar
Nope. In fact i just put new ones in so the sway bars are tighter
hondaruss
Sep 10, 2008 03:29 PM
karizzle
Mar 27, 2007 05:49 PM
finestimage12
35
Dec 5, 2005 07:28 PM
PrYnCeQT
Oct 6, 2004 07:13 PM
Xudus
Mar 27, 2002 04:59 PM
