8th gen 2008 Honda Civic Sedan - can shops not fix bad front camber?
Rep Power: 0 8th gen 2008 Honda Civic Sedan - can shops not fix bad front camber?
I just got new tires, and suddenly realized my car is pulling hard to one side.
- Is it normal for new tires to suddenly affect pull?
- I took my car to get an alignment, they fixed toe, but said can't adjust camber for Civics. Is this true? Front only
Received 1,442 Likes
Rep Power: 338 Re: 8th gen 2008 Honda Civic Sedan - can shops not fix bad front camber?
did they pull before or after alignment?
camber - yes, not adjustable, maybe by a few 0.1 degrees
Rep Power: 0 Re: 8th gen 2008 Honda Civic Sedan - can shops not fix bad front camber?
Rep Power: 125 Re: 8th gen 2008 Honda Civic Sedan - can shops not fix bad front camber?
Bad pull can be caused by alignment for sure but IN MY OPINION, you would have noticed it before new tires. On new tires, since they are square across to rolling axis, they would not pull unless chamber was so far off, you could visible see it. If the toe was say way out both front towed outward, ever little uneven places in road would tend to cause car to go that way. Years ago when cars were really sloppy built, they actually toed them in some to keep that from happening. Pull is usually caused on Civics by not rotating tires enough, tires wear on one side and then they are like rolling a drumstick ice cream cone straight..not going to happen. Switch them to the back. If it goes away, you probably have a defective tire or bent rim if they happen to be steel. Something they did or was already done and just happened to be on back when you got new tires. You did get 4???
My 2007 Civic is the one with the rear camber like a stock race car. Think it's -2.0. It's actually hard to keep up the rotation enough to keep tires on rear from getting a one side wear pattern. Once it starts, there is no stopping it. I rotate ever 6K at Cosco and still not 100% sure it is enough. I have a set of rear control arms to fix it. Takeoff from a newer Civic before Honda learned the error of their ways. Civics for me have always had tire problems. MY old 1985 and my 1994 after 40K of miles would always thump and howl from odd tire wear or just could have been tire brand I use to run. My 2007 have had wires coming out after less then 40K on last two sets of 80K quality tires. That could be something however to do with my 20 some-think driver.
OP still needs to post ALL of the alignment numbers so we have something of worthwhile to work with.
Toe, camber, caster, thrust angle, and SAI/IA if they took those measurements.
Brand new tires can have pull problems too.
yup, I saw - if the problem goes away when he swap front/rear tires, it means it's tires, if not, he need work further.
Someone needs to wake up the OP first.
