Worn front control arm bushings
Old Jul 28, 2020
Nick Robilliard's Avatar
Nick Robilliard is an unknown quantity at this point
Hello
My 2006 civic sedan (~120,000km) failed a warrent of fitness because apperently the front control arm bushings are worn. They didn't specify a side or whether it was the foreward or rearward bushing. Is it just the larger foreward bushings on the front lower control arm that usually need to be replaced or both the foreward and rearward bushings on either FLCA?
Thanks
Old Jul 28, 2020
Colin42's Avatar
Re: Worn front control arm bushings
Pull a wheel off and take a look.
Old Jul 29, 2020
Probably the compliance bushing (forward), but none of us can see what you're dealing with.
If it's not obvious to you., ask whomever inspected the car to show you exactly what the issue is
Nohippychicks
Suspension
Sep 30, 2019 04:26 AM
metron
Apr 27, 2015 12:09 PM
Ashhole
Sep 10, 2011 12:00 AM
scrimp
May 14, 2007 01:00 PM
icebergslim
Dec 23, 2003 07:45 PM
