Rough ride
Old Jan 14, 2021
Uscman84's Avatar
Uscman84 is an unknown quantity at this point
Rough ride
Anyone experience hard jarring sounds coming from the front when going over bumps or dips? Almost like there is no suspension or smooth remount on the shocks/struts. Tires are 235/40/18. Not a lot of rubber but even with stock rims/tires still felt the same. Could it be struts or engine mounts? It’s just not smooth over bumps.
Old Jan 15, 2021
Re: Rough ride
when did the shocks(struts) get replaced last? stock are likely 30k miles in harsh use
Old Jan 15, 2021
Uscman84's Avatar
Re: Rough ride
I just purchased the car recently. I honestly have no clue. It’s just super rough over bumps. The loose change in my coin tray shakes. Lol.
Old Jan 15, 2021
Re: Rough ride
then full suspension inspection is warranted.
struts, control arm bushings, mounts, rods, ball joints, etc
Old Jan 15, 2021
BrotatoChip's Avatar
Super Moderator
Re: Rough ride
What did you drive before this? The suspension on the Civics seems to be a bit firmer than some other cars, you may just not be used to it.
Old Jan 15, 2021
Uscman84's Avatar
Re: Rough ride
I have a chevy Colorado. But if had two of 8th gen. Just seems like suspension is shot
Old Jan 15, 2021
Re: Rough ride
time for inspection
Stacyracing33
Suspension
Feb 17, 2019 04:29 PM
asummers
Jan 3, 2013 06:56 PM
scooty
Jul 7, 2012 11:49 PM
stefankowolik
Feb 14, 2005 09:26 PM
silverdevil
Jul 1, 2003 02:37 PM
