Blown Struts???
Old Jun 30, 2003
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Arrow Blown Struts???
Ok, my ride quality has degraded substantially, my ride is very bumpy, tires squeek when cornering (slow corners say 15-20 mph) and when in 1st gear from a stop. I'm taking the car to the dealership tomorrow but I'm affraid they might tell me they're not blown. I know they are. Is there anything else I can tell them as a "symptom" to make sure they change them?
Old Jun 30, 2003
robbclark1's Avatar
Retired suspension supermod.
You can push down on the rear shocks and see if the butt bounces. It should go back to "resting state" after about one and 1/2 bounces. Any more than that should be an indication that they are blown. Other than that bumpy ride, bad handling, etc.
Old Jun 30, 2003
Rob, it's not the back, it's the front ones. Same applies, tho. It feels way too soft, it should be firmer.
Old Jul 1, 2003
Lek's Avatar
Lek
Lek is an unknown quantity at this point
My 2001 OEM sedan doesn't bounce too much, it just sways and rolls with the road a lot. Is that a strut and spring problem or is it just bad 7th generation suspension design problem?
Old Jul 1, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
It's completely normal for a Civic. It's called body roll on the outside, and spring compression on the inside. Spring compression controls how much the car leans side to side. Soft springs allows it to roll, making the ride comfortable in normal conditions. Stiff springs prevent more "roll" and improve handling while compromising with comfort quality.
"Body roll" generally comes from the rear. When a car is turning, the weight distributed to the rear suspension is being depended on for a healthy turn. If the suspension in the rear is not stiff enough, the rear of the body causes it to become more unstable and uncomfortable to turn hard. Not to mention more difficlt.
The only supplemental device used to decrease spring compression in a car are anti roll/sway bars. The thicker the bar, the more stress from "rolling" will go on it than the springs also improving handling in the rear.
Keep in mind that it's a supplimental device. A bar too thick on a car with springs too soft can potentially damage your car's rear subframe. A bar too thin on stiff springs will do nothing for the rear.
The front anti sway bar does a similar job but offers different results in how well a car will steer. If you're curious about it, we can get into that.
Old Jul 1, 2003
robbclark1's Avatar
Anti-roll bars aren't the only device. A nice set of stiff lowering spring and high set dampering shocks will greatly reduce body roll more than ARBs.
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
Wariogamer
Sep 29, 2015 09:49 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
