- 1997 Civic Coupe Tinting
- Help with problem...CEL code 12 but no EGR....
- 95 civic LX overheating
- 93 tail lights for my 99 si?
- Seat leans to one side
- 95 civic cx upgrades?
- turbo a d15
- Cx Mpg?
- 5th gen Civic coupe build, please comment
- Swap seats (left to right) in 94?
- Window seal/weatherstripping
- '92 DX randomly stalls, hard to restart
- help me with me D15b
- Wanna Rebuild 1995 Civic DX
- Engine Swap Years
- `80 civic 1500 diesels (runs on) after shut off
- 95 civic vx b16 swap need help
- 1995 Civic LX Battery Connection
- Relocate battery?
- 89 civic + 92 teg motor + 94 ls tranny = my personal hell
- help I am tired of searching I give Fuse keeps blowing
- Gen 2 body panels need to finish rebuild please help
- 94 dx losing power and cutting out
- '92 DX overheating?
- 5th Gen coupe pics
- Speedometer problem wont pass 40mph!
- 91 civic dx Motor swap.
- end of the line for daughters 92?
- B18 boost or K20 all motor
- Found a burned exhaust valve--seeking advice
- 92 eg light flicker???
- 88 dx horn fuse
- speedometer is acting up
- annoying humming
- Head Light Bulbs
- problem in 95 ex
- 89 si
- 86 running out of gas at high speeds
- swap b16 info
- 95 Civic DX engine stalled while driving- Help
- Help! No Fuel, No Spark! 92 LX
- i need to find parts for a 93 civic DX EG
- 88 dx engine model
- b18a1
- 1991 Civic Won't Start....Help!!!
- 92 Civic 4dr DX
- Smelling Gas
- 94 wheel bounce and brake problem
- just bought an 87 DX HB - any ideas?
- Whats the best intake!!!
- 95 civic engine swap
- engine swap 94 ex
- 15 problems I can't fix myself
- 1991 civic mods
- how to swap from throtle body to port injection???
- WTB 1992-1995 Stock exhaust
- Sunroof stopped opening on my 93 EX
- slid into a kerb yo, while doin mad tyte tokyo dorifto
- Sidelights and Full Beams ok, no Headlights
- msdabair
- 89 civic no start
- 1993 civic timimg belt
- Fender interchange
- Rice Vs. Non-Rice??
- 91 ef problems
- wiring harness
- check engine light
- how to install oem foglights 94 civic hatch
- '92 civic ex problem.. please help =/
- used '84 suspension parts?
- exhaust help
- 01 civic blowing fuse
- 1986 Civic Si Head Gasket
- vss help, need quick answer!
- 89 civic 1.5 will not start after driven
- Can't find brackets for new seats.
- 4door Body kit fit on a 2door
- How to install tail lights 92hb
- 93 hatch ISSUES!!!
- 93 Dies
- what intake should i buy? shortram or cold air?
- which engine is best?
- 94 Civic coupe (D16Z6) Automatic transmission problems...
- Looking to buy Civic- Need opinions!
- 93 Civic 5-speed - What type of fluid?
- 94 civic new motor wont start
- need help
- Ok so I am new....A little long
- 91 dx with b18a swap
- 95 1.6 hard to start
- model years
- Help: Shuddering rear end
- sites-parts and installation places?
- 93' Civic Auto to 5-Speed
- 85' Civic DX hatchback
- A new potential Civic Owner
- b16a2 help
- D series cam and valve springs do much?
- Leaking Distributor
- motor question
- Selling Radiator 50 cash band new!!
- Selling Exhaust
- Hood wont shut completely!!!Need advice!!
- 82' engine swap
- 85 crx dx clutch problem with clutch not releasing
- Replacing thermostat for fan bypass crx dx
- 1991 civic dx upgrades
- Drivers side door wont lock
- Civic seat foam any aval?
- Dead Alt
- fans not turning on help on crx 85 mt
- Selling vintage ENKEI mesh alloy wheels
- D16Z6 VTEC engine?
- Backlight on climate control/Gauge cluster in 94 civic
- 1992 Civic DX AUTOMATIC shifts but will not go anywhere
- 94 Civic EX (D16Z6, automatic trans) mpg
- Clutch/tranny squeal
- removing the fuel feeder on filter..
- d15b7 having trouble starting..help
- Cold Weather and my car
- ignition timing
- about to do a tuneup
- What would you pay for this car???
- Idle mifire trouble help!
- Installing Fogs
- 92 civic lx tranny problems.PLEASE HELP!!!
- 1994 Honda Civic 1.6L (D16Z6) died while driving...
- d16z6 problem
- 95 Civic EX Owner Newb starting problem and Advice
- Head Gasket Replacement 1995 civic lx
- B18b Swap from 95 Teg into 95 civic DX
- 1991 civic SI rough idle poor mileage
- 94 civic ex ... is it vtec?
- New to this fourm and i have a new car
- 92 LX Tranny Problem
- Please help.....1995 Civic Question
- 94 Civic Ex what to do next
- ef hatch build!!!
- 94 civic speedo jumps than stops working....
- Transmission Has Problems Shifting From 2nd to 3rd
- 1988 Civic sedan (ED3) Turbo project
- door window fitment question
- 88 civic dx for sale $600
- Honda Pros.. Need Your Help !!!
- need help a.s.a.p on my 95 hatch!!
- Just replaced my distributor and my car still wont start. Appreciate any advice.
- Help! How to convert bumper,sedan to coupe??
- 91 Si Rear Bumper Cover Removal
- how to remove the A/C from a 94 civic ex
- Is this swap possible?
- Dx-si motor swap
- looking to buy a cold air intake for my 94 EX
- New to the import scene
- Suspension suggestions for a '95 dx coupe
- 95 dx manual running rough after 2nd start
- d17a2 into a 94 civic dx (d15b7)!!
- 94 honda civic 1.6 vtec burning oil
- 84 wagon needs a carb
- Head Gasket Replacement on 92 d15b8?
- New Civic
- Fuel Testing Banjo Bolt
- Battery fine but won't start....
- Car Trouble, need advise
- 1990 civic sidemarker gremlins
- '90 civic RUNNING LIGHT gremlins
- Dash Removal...PLEASE HELP!
- Y8 into 91 SI - engine won't crank
- 89 Civic Wagon Suspension
- 94 Civic EX
- 89 DX hatchback How do you switch to MPFI?
- 95 civic
- 89 Civic Alternator help needed!
- 93 Civic Strut Bar
- What body kit is this?
- Anyone tell me what body kit this is?
- 87 Cv Joints
- Eagle rods for D15B2?
- Problems with D15b7
- Bushings/Common suspension problems?
- 1986 Civic 1500 3bb carb
- 93 civic with running lights problem
- D16z6 engine problems.. NEED HELP! :(
- Engine swap from 94 civic to 93 dx
- XS Engineering Subaru WRX vs Top Setup Honda Civic EG6
- options for d16 what can i do?!
- HELP Crankshaft bolt issues...
- !!!!complete part out thread!!!!
- 1995 cvt tranny making loud reving sound
- 94 Civic Si - Wipers ALWAYS ON!!
- 95 parts on 92????
- '91 Temp sending unit help!!!!
- 94 Civic Coupe - Not starting
- need help 3.2 TL swap in 92 Hatch
- What are possible Causes of code 16? 91 civic
- Help on lowering 94 civic
- need help with swap for 91 civic
- Need help with my Civic 85
- need help on 95 hatch!!!
- Idle problems
- mini me issues
- Hey, Questions for Pros...
- 1992 Sedan... Yes... Sedan...
- 1994 Sunroof pulling unevenly
- D15b4 (aust)
- Do I have del sol tranny in my LX
- what motor should i get
- B16A Swap, Is it worth it?
- Clutch Going to the Floor, Not engaging
- i need help to save my 2nd gen civic
- Head Gasket...or???
- Can someone measure a d15b1 dipstick for me?
- 95 EX, Bad miss after warming up, 1.6 v-tec
- NEED axle help!!!
- Idle oscillates from 200 to 1000rpms?
- Help cooling fan not turning on let's pinpoint !
- Wealth of problems all at once!
- 81 civic ball joints
- 1987 Civic - fuses?
- I have an EJ1 Shell
- won't start
- rpms
- 93 Civic SI Rear Wiper Motor Needed
- crx 85 carb Help me find the perfect idle !! 99,9 fixed !!
- 93 Civic SI Cooling Problems
- 85 crx easy problem to fix
- 1991 Honda Civic advice
- '89 EF motor options
- AD3 Civic
- 92 civic dx hatch won't start
- Need help with questions about 1995 Civic VX
- 89 civic suspension upgrades
- CRX - EG8 (which one is better for modification and swap) ?
- '96 Civic Sudan - Sound System Upgrade
- Need help with 1992 Civic DX ECM
- 1995 Civic Glacier 1.3 starting problems.
- Transmission Swap questions/help?
- bumper repair 2005 special edition
- '95 Civic burning a LOT of oil
- A/C problems
- Help me with my stupid electical problem!!!!!!!!!!!!!
- 89 Civic GSR swap
- 89 civic adjustable proportioning valve
- 94 EX Z6 civic missing ect....
- wheels offset help...!!
- quick question about my key and my ignition/door locks
- D15B7 Timing marks question and confusion?
- Questions???
- 5th gen Civic:R12 pressure readings for high and low side
- Quarter glass
- Civic 90 Sedan Mirror
