1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
New 1989 civic si
Old Feb 17, 2014
Dasquad323's Avatar
Dasquad323 is an unknown quantity at this point
New 1989 civic si
Whats up guys this is my first post. So i just got a 1989 si, and it had a zc swap already done to it, the motor and tranny are very strong. But the person who swapped it cut out alot of wires, for example the o2 is cut and i cant find the wire. So what im wondering is if so any wires are cut, should i repair it or replace the entire wire harness. And if so which wire harness could i swap into it other than the si ones. Thanks guys,
Old Feb 18, 2014
Lordsin's Avatar
Lord Sin
Lordsin is an unknown quantity at this point
Re: New 1989 civic si
I'm pretty sure the SI ones. The dx/lx D15b2 wire harness are different. Can you trace the wires? Maybe you can find where the o2 plugs into or get a plug and solder it in place
Old Feb 18, 2014
Dasquad323's Avatar
So only the si harness would work? And thats the thing many wires have been cut an i cant find the wires. Also some vacuum lines are not connected to the intake. But the car still runs strong. Also the ecu is throwing a code 13 but thats it, if the o2 sensor is cut shouldnt there be a code for that aswell?
Old Feb 19, 2014
Lordsin's Avatar
Lord Sin
13: BARO Sensor (Atmospheric Pressure)
defective circuit or unplugged / defective sensor
I believe code 1-2 is oxygen sensor. And it should come up unless bypassed somehow. Try following all the wires around and take some pictures maybe we can help you out.
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
