1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Starting from the bottom
Old Nov 16, 2013
OldFaithfulAndI's Avatar
OldFaithfulAndI is an unknown quantity at this point
I have a 94 civic coupe that I have had for about 3 years. I haven't given her the proper attention and I finally have the opportunity to. I was thinking about getting new axles and rotors first. Any suggestions as to whether or not I should start there?
Old Nov 16, 2013
Re: Starting from the bottom
Does it NEED these things?
How about maintenance stuff, like a timing belt job?
You won't need axles or brakes if the engine won't run!
Be good......Prioritize
Old Nov 16, 2013
Well I am doing an h22 vtec swap.The engine does idle a little bit low from time to time. The issue I am facing is that within the next 2 months I really won't be driving it and idk if I should do some quick fixes to an engine I won't be using.
Old Nov 16, 2013
Well, why didn't you say so?
Should have a boatload of stop when you have a ton of go.
Um.....Might want to wait and see.....axles may need to be very different for a swap with a different trans.
Old Nov 16, 2013
if you are going to install different brakes, now is the time.
if you have the H22 out the car, wait for the axles, unless it is showing signs that it will not be running for long.
Old Nov 16, 2013
I will look into brakes and new rotors the old ones are pretty rusted. My axles are in pretty rough shape as well. I will be pretty much replacing most of the components in the car. I am a noob to the more technical side of things so if you guys could just bare with me lol.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
danace99
23
Jun 28, 2015 08:49 AM
mievil
Apr 28, 2015 11:02 PM
black2k1vtec
Dec 6, 2001 09:49 PM
EvoAdmin
Aug 28, 2001 12:07 AM
