New member, 1st civic
Subscribe
Nov 22, 2013
Sup Everyone,
New Member and just picked up my first civic.
its a 96' coupe, primed black, lowered with idk what type of shocks
the Engine I have no clue on, lol.
I Picked it up from my sis-n-law, running, still waiting on papers from here
but it needs smog.
I was looking at the motor , it says D15b8 on the motor and has
a 16 valve head. don't kno anything on this. tried a search and comes up it might have had a head swap? not sure.
Any help will be Appreciated.
Also will be doin some work on it, Shave it up, build a center console, going to be picking out colors for interior and do some dash work.
don't know what to use on this car, being my first time owning a civic.
Nov 23, 2013
Re: New member, 1st civic
Welcome to the forum.
Nov 23, 2013
welcome! moved to 6th gen, since it's a 96 aaaand moved back since it's actually an 95...
if engine marked as D15B8, it seems swapped head.
D15B8
Found in:
1992-1995 Honda Civic CX (U.S. model)
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 %u00D7 84.5 mm (3.0 %u00D7 3.33 in)
Compression : 9.1:1
Power : 70 hp (52.2 kW, 71.0 ps) @ 4500 rpm
Torque : 83 ft%u00B7lbf (11.5 kg/m, 113 Nm) @ 2800 rpm
Limit : 5800 rpm
Valvetrain : SOHC (2 valves per cylinder)
Fuel Control : OBD-1 MPFI.
Nov 23, 2013
Quote: I was looking at the motor , it says D15b8 on the motor and has
a 16 valve head.
Are you sure it's really a 16 valve head?
Did you pull the valve cover and check how many rocker arms there are inside?
Reason: I think one can swap valve covers without swapping the head.
(Not positive, but I'm pretty sure it can be done. 'Now you have the name without all the hassle of actually getting 8 extra valves!')
D15B8
Found in:
That info appears to indicate this is a swapped 16V head on top of a swapped early engine, IF it really has a 16v head.
OP:
If it runs good, then good (for now).
If this really is a Frankenstein swap, I think you really should make contact with whomever built it and get a list of what parts came from which cars and what years and stuff so when something breaks you can find parts with a minimum of hassle.
OBD 1 or 2?
Which PCM does it have?
How do you get codes now?
Quote: but it needs smog.
Sellers responsibility?
If sold within a family, is there a clause about no smog necessary?
IDK, I don't live in an area that has smog checks.
Nov 23, 2013
sorry about the mix up, it is a 95' I was half asleep typing last night.
I haven't got a chance to take the cover off, im going to check it ina bit
Its still an obd1 I believe, and the person I got it from she was the 3rd owner, she doesn't know the last owner who did the work, but I am on a mission to find out. again it is my first civic, last time I had a Honda was over 10 years ago, so not sure what is good to add to it as in , mods. My background is more of a mini truckin, but always digged the Honda civics
Nov 23, 2013
D15B8
Found in:
Compression : 9.1:1
Limit : 5800 rpm
sdaidoji, need to move to 5th gen now?
Quote: sorry about the mix up, it is a 95' I was half asleep typing last night.
95 should be OBD1
Maybe it IS the correct engine for that car.
I can't see someone swapping an 8 valve engine into anything, that would be a downgrade for most.
Is the car a USA CX? Hatchback?
Maybe someone just stuck a 16v valve cover on for looks.
Check my profile, I have one of those too. https://www.civicforums.com/forums/garage/1987-Mazda-BSeries%20Pickup-831-ezone.html
Nov 23, 2013
it is a coupe, and I didn't get a chance to get the valve cover off today, but I will def check it out first thing in the morning.
Subscribe
