1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Help with TPS error
Old Dec 29, 2013
1exis's Avatar
1exis is an unknown quantity at this point
Help with TPS error
Hi guys,
i got a D16z6, P28, with Check Engine giving code 7 (TPS).... the car is running "normal", the plug is connected but the green cable is disconnected.... i reconnect the green cable, reset the Check Engine code and started the car, the Check engine turned OFF but the car start failing without check engine.... i decide to disconect the green cable again and the car is running "normal" with check engine on...
D16z6 with High comp pistons and P28 ecu, fuel pressure reg., adj. cam gear, header, air filter, stock cam.
Any clues?
Old Dec 30, 2013
1exis's Avatar
Re: Help with TPS error
anyone?
JetsterDajet
52
May 8, 2016 12:11 AM
Tyler93
Mar 20, 2016 09:03 PM
brash99
Sep 29, 2015 08:42 AM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
thaler4cuse
Sep 7, 2015 08:25 PM
