1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
help
Old Mar 10, 2014
chaospunk's Avatar
chaospunk is an unknown quantity at this point
help
hello all i recently got a 95 honda civic ex coupe with 90000 miles on it. ive been having problems with after the first week stalling and low idle shocks all blew out just a bad buy. i did get it to stop stalling but the idle is a little high so they said when i went to get the emissions done today which i failed. i changed the spark plugs, air filter, fuel filter, had the valves adjusted and had to change the power steering pump.
now my problem is i failed emissions today it says primary emission test performed: TSI-fail
HC ppm standard 220 mine was 517
CO% standard 1.20 mine 0.82
CO2% mine 12.8
02% mine 2.1
mode: high idle - fail
HC ppm standard 220 mine 289
CO% standard 1.20 mine .92
CO2% mine 13.1
02% mine 1.6
anybody have any ideas what i can do to bring the emissions down?
Old Mar 10, 2014
Poopies's Avatar
Super Moderator
Re: help
How about those fuel injectors?
Have you been running any cleaner through your system?
How does the catalytic converter look under the car?
Have you tried hooking up an OBDII scanner and reading the codes yourself?
Old Mar 10, 2014
chaospunk's Avatar
Re: help
i ran injector cleaner and the catalytic converter looks to be in a good shape its an newer after market i believe. i dont have obdII scanner i may have to pick one up
Old Mar 10, 2014
Lil-low-civic's Avatar
Lil-low-civic is an unknown quantity at this point
Re: help
Make sure it's not a test pipe
Old Mar 11, 2014
chaospunk's Avatar
Re: help
I'm gonna get under it tonight and make sure it's not a test pipe. If that's what it is that's why it would fail?
Old Mar 11, 2014
chaospunk's Avatar
Re: help
There's 1 cat under there and 2 resonators
