1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Civic no start? Iacv cause?
Old Jan 28, 2014
Cej1's Avatar
Cej1 is an unknown quantity at this point
Hey everyone I have a 95 civic coupe d16z6 it started idling up and bad pretty bad so I heard to take off my tb and clean it and the idle air control valve on the back if the intake good with carb cleaner so I cleaned both good let it air dry for about 45 minutes reinstalled all sensor wires coolant lines and it started up once idled real low then died now it don't start but it will crank good, I checked the fuel pump fuel rail, it has spark on all cyclinders and all the plugs are on the rift sensors I've changed the map sensor and yet to try the iacv? Anyone have any ideas?
Old Feb 7, 2014
Lordsin's Avatar
Lord Sin
Lordsin is an unknown quantity at this point
Re: Civic no start? Iacv cause?
This happened to me on my D16y7 when I swaped the stock intake manifold for the Z6 intake manifold. I had the iacv plug and not sure what the other one was( will check later tomorrow. -12 degrees here) I just switched those back and it started. Could also be a crankshaft sensor.
CarStuff
Dec 6, 2020 12:52 PM
civic_gt
Apr 19, 2015 08:15 AM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
