1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Gas leaking from fuel filler neck
Old Nov 10, 2014
trav719's Avatar
trav719 is an unknown quantity at this point
Here's a head scratcher. I was cleaning out my trunk this weekend and noticed old varnished gas on the inside of the trunk coming from where the gas cap and inside body connect in the trunk. I opened the fuel door and noticed gas actively dripping from the cap. I'd filled up the day prior, but had driven 60 miles or so already so it couldn't be over filled. The car had been sitting for about an hour as well. I took the gas cap off and depressed the door to see if the fuel would drain but the entire filler neck was full, and it was still slowly pouring out. It's like the gas tank was full of pressure or something. I replaced the gas cap but am still concerned that I may have a problem with my vacuum system or fuel system.
Anyone have any ideas as to what the hell is going here?
Old Nov 10, 2014
Re: Gas leaking from fuel filler neck
What car is this about? (Post this info whenever you start a thread please)
Had to look at your history....89 Civic something?
No clue from me, that car is really before my time.....would have to look closely at it....
Rubber O ring gasket on the fuel cap is cracked or split?
Fill neck rusted out?
If you fill the tank and keep clicking to get the next dollar in it, stop doing that.
Old Nov 12, 2014
trav719's Avatar
It's an 89 Civic LX. I do top off the tank, but this was happening after id driven 2 or 3 gallons worth of fuel from the tank, so it couldn't have been overfilled at the time.
The new gas cap seems to have solved the leak for now, but I'm concerned that I may have a vacuum problem.
Old Nov 12, 2014
Slosh? Parked on an incline or tilt? IDK.
How so?
Did the original gas cap have a vent, and the new one doesn't?
Or something else?
Old Nov 13, 2014
trav719's Avatar
Not parked on an incline, and haven't taken the thing off of any sweet jumps. The old cap didn't have a vent but the new one appears to.
zaboomafoozarg
May 30, 2015 09:21 AM
McD
Apr 29, 2015 03:50 PM
green01civic
Apr 29, 2015 01:36 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Lightman
Nov 10, 2001 06:44 PM
