1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
95 civic speedo help needed
Old Apr 1, 2015
kracker's Avatar
kracker is an unknown quantity at this point
i haVE A 95 civic dx, and my speedo doesnt work. what would cause this?
Old Apr 1, 2015
Re: 95 civic speedo help needed
Check for fault codes. Got any? What are the codes?
Anything else not working correctly?
If no codes related to it, then it could be a bad speedo head.
Old Apr 2, 2015
kracker's Avatar
no codes or check eng lite, SAS light is on though
Old Apr 2, 2015
Old Apr 4, 2015
kracker's Avatar
how do i determine if its VSS or speedo ? anyone have VSS diag procedure?
Old Apr 4, 2015
If the VSS truly failed, I fully expect a related fault code in the ECM, which you do not have.
Got factory cruise control? Does it work?
If you do have cruise and it still works, the VSS is good. Stop there.
To test the VSS in-circuit, I'd backprobe at the most convenient connector, the yellow/white at the sensor itself or yellpw blue at any other connector in the circuit, watch the meter toggle from a voltage to zero repeatedly as the car is slowly rolled on the floor.
I'd plug in a scanner and read VSS value while driving, that's quick to verify it works.
Old Apr 5, 2015
kracker's Avatar
no cruise on the car
mattdoc
Mar 14, 2017 12:10 PM
Myredjonda
Apr 14, 2015 07:00 PM
Hrddrvs
Apr 11, 2015 11:22 PM
