1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
My new 1991 civic 4-Speed EF problem, CEL on
Old Jun 20, 2014
Yuta's Avatar
Yuta is an unknown quantity at this point
Hi guys,
New to the forum. Recently purchased a 1991 EF 4-speed. I have put around 400 miles on it. Really amazed by the gas mileage. I got 33MPG, mainly highway. It may seem to be nothing to Honda veteran, but I am really impressed for what this old machine can do.
I put on a new muffler, old one is rusty and leaking.. I adjusted throttle cable, it was too tight which led to high and fluctuating idle...I also cleaned the throttle body... It runs fantastic...
The problems....
1. It has loud noise from valve train (maybe?)....Is it normal for Honda? maybe just the valve clearance? Or distributor?
2. While I was driving along highway, the ECL came on and I noticed that the Speedo was not working. (It was working when I purchased it)...is the ECL related to the speedo? I have seen some vehicles with no speedo but still would not trigger ECL..... I drove about 100miles on highway after this problem occurred....not a lot of feel in power loss, water temp remain the same... Will Autozone be able to read the code, considering this is an old vehicle with OBD-I (I guess) ?
Thanks in advance
Old Jun 20, 2014
Re: My new 1991 civic 4-Speed EF problem, CEL on
What's an ECL? You mean CEL?
They need the valves adjusted periodically. I think one that old would have specified every 30k for valve adjustment.
No, DangerZoo can't read codes. You'll have to do that yourself.
Speedo quit along with CEL means the ECM probably lost the VSS signal for some reason, wiring/sensor/fuse related?
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
rcolosi
Apr 29, 2015 07:48 PM
Rinzlor
Apr 24, 2015 10:33 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
