1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1995 Civic Starting problems
Old Aug 13, 2014
Chickenhawk327's Avatar
Chickenhawk327 is an unknown quantity at this point
I have a 95 civic with a 1.5, 5Spd. I have a brand new main relay, good fuel pump, (pump comes on when jumped), good spark, and a good ign switch (already tested), fuses ok (underhood and dash), Have good power and ground to relay main relay only clicks once when key is "ON II" been having too much trouble with this car, had it for about a month and started having an intermittent starting issue which led me to replace the main relay, and now i cant get it to run again, OK while i was typing this the key was on and the relay decided to click and i just started the car, BUT this is not the first time this has happened to me sometimes it starts, sometimes it doesnt, no matter how hot or how cold it is it just happens randomly.
Sorry for the huge write up i am at witts end and need help! any info is greatly appreciated!
Old Aug 13, 2014
Re: 1995 Civic Starting problems
P.S. i am new to the entire Rice Burner world i have only owned older fords before!
Old Aug 13, 2014
Check the ground wires on the thermostat housing.....
See if you can find someone with a good ECM to try in it. Just a hunch.
Old Aug 19, 2014
ive checked the wires before, but today i happened to open up the dist. and pulled the rotor off and it came on, could be i moved something or just the car deciding to work again?
Old Aug 19, 2014
The PCM operates the main relay, but it needs good grounds to do that. Most of the grounds are on the stat housing, so unless you bumped a loose connection I doubt your removing the dist cap had anything to do with it.
Why did you have the key on while messing with the distributor? Good way to get zapped.
Found a good PCM to try yet?
Old Aug 19, 2014
yea good way to get zapped Haha im so frustrated that i didnt even think about it but ive been zapped by a dist. before..... but all day throughout the day i went outside and tried 4-5 different times and the relay would click on, and fire the fuel pump after about a 5-10 second delay and the car would start and run, until just a minute ago i tried again and the fuel pump would not come on even after waiting a few minutes with the key on. Still bumfuzzled. Still havent found anyone with the same generation pcm/ecu
Old Aug 19, 2014
Also the ground connection at the thermostat housing is tight and clean.
Old Aug 19, 2014
Open up the ECU, got any leaking capacitors?
Just an example, they don't have to be leaking that bad to be a problem.
Quick google came up with several items about bad ECM/ECUs.
Here's one
http://www.hondacivicforum.com/forum...t-start-90696/
Old Aug 20, 2014
i have looked at the ecm before didnt see any leaky capacitors, but i will double check again tomorrow, and the link you posted sounds exactly like the problems im having so tomorrow im going to re check the ecm, and take off the thermostat housing ground and clean it. anything else you think i should check while im at it? and will you be online tomorrow?
Old Aug 20, 2014
I guessed at a cause based on the symptoms you described. You could monitor stuff at the main relay to see that the ECM is really not turning it on at the correct times....that requires more research and work and equipment.
I usually check in at some point daily but I can't be on 24/7. I have a job and all that.
Old Aug 20, 2014
Alright thanks! ill keep a steady update of what happens and try to track down a friend with an ecm
Old Oct 3, 2014
buc18's Avatar
buc18 is an unknown quantity at this point
Did you ever figure anything out? I am having same problem with 92 Civic.
Old Oct 4, 2014
sjrnfl1234's Avatar
sjrnfl1234 is an unknown quantity at this point
Make sure that all power is going to all electrical system.
Have you ever checked the output signals from starer motor?
If it doesn't get enough voltage ,starter motor will not work( if there is no problem on starter motor you can just hear clicking sound without cranking.)
I am not sure that your civic has those sensors.. you need to check..
MAP,MAF, CKP , IAT or Idling sensor.
If one of those sensor does not work, it can also effect on your stating problem.
If you have DMM or lab scope, then you need to back probe each sensors then see the result or signal waves.
You can see the values or signal waves for each sensors on google.
Or i guess you can find those result on out forum
CarStuff
Dec 6, 2020 12:52 PM
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
Braun
Apr 23, 2015 09:03 PM
McD
Apr 16, 2015 10:46 AM
SSMatey
Apr 13, 2015 06:09 PM
