1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
No fuel pressure in 90 civic si
Old Nov 9, 2013
chuckklr04's Avatar
chuckklr04 will become famous soon enough
Has new pump relay,pump, regulator, and filter. Pumps turns on, then shuts off even if line is open .
Ideas?
Old Nov 9, 2013
chuckklr04's Avatar
Re: No fuel pressure in 90 civic si
thinking it may have a bad relay, even though it is fairly new. Only been in 6 months.
Old Nov 10, 2013
chuckklr04's Avatar
Replaced relay, nothing. Any ideas at all? Computer problem ? Module?
Bueller? Bueller?
Old Jan 1, 2014
chuckklr04's Avatar
Think it jumped time due to failed cam belt tension-er. Put in a new cam belt and water pump two years ago. Checked the belt the other day. Seems to be really loose.
Thanks for all the help! LOL!
Old Feb 8, 2014
chuckklr04's Avatar
Jumped time due to weak timing belt spring. Low compression in two cylinders. bent valves, Thanks for the help. Sold it for 425 bucks. did not feel like doing the heads. Thought the civic world would have great support. I was wrong.
Old Feb 9, 2014
I don't recall noticing your posts....Sorry.
Sounds like your real problem was quite far different from fuel pressure.
It should have sounded very wrong during cranking (the sound of the starter working against compression).
CarStuff
Dec 6, 2020 12:52 PM
Jonnie.
Jan 13, 2019 11:21 AM
usajags84
May 10, 2015 08:11 AM
