View Full Version : I.C.E. & Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45
  1. Quetsions about Adding new lighting options
  2. Voltage Stabalizer
  3. where to find amber front turn signal bulbs. (01-03)
  4. 01 sedan audio system overhaul
  5. Attempting to install an alarm on my 7th gen
  6. Radio Code under CD Player????
  7. Anti-Theft system acting up.....
  8. another person looking to replace new speakers
  9. Dim Turn Signals
  10. are these ebay lights worth it..
  11. AC/AC light wont turn off
  12. brightest/whitest halogen?
  13. No sound from speakers!!! help!
  14. Radio Problems "help"
  15. 03 civic sedan..
  16. OEM Black Gauges Installed
  17. remove bulb in cluster for airbag and abs
  18. DIY: EBAY FOGS... need a.s.a.p... HELP!!!
  19. 4 channel wiring diagram
  20. fuse for 5w bulb?
  21. Looking for ideas on trunk setup
  22. just installed electronic (LED) flasher
  23. Powa Distribution Block
  24. Aux input advice.
  25. Aux Input For Factory Headunit
  26. alpine volume knob ring?
  27. 0 Gauge From Alt
  28. 2005 Civic EX satellite radio
  29. 06 Civic LX horn confirmation/anti-theft system
  30. Question about Crutchfield and My Set-up
  31. Custom Boxes For Anything
  32. Question-Hardwiring LED's & Neon
  33. 2002 LX instrument panel/dash pics..
  34. Need code for audio head unit for 2001 ex
  35. Speedometer Recalibration
  36. Remote Wire Help
  37. New birthday "mod"
  38. 2002 LX power door lock question
  39. Sub box ideas for 04 coupe?
  40. Head Unit Wiring
  41. does this fit??
  42. Ebay Altezza LED Tail Lights
  43. Stereo Deck
  44. DIY: APEXI NEO menu walk-through
  45. Got my viper alarm working
  46. Aux-In Not Activated
  47. Back speakers out
  48. Subs/Speakers
  49. no more grilles
  50. Civic Wire Harness for trailer
  51. codes p1298, p0138
  52. 04 Civic Dash Kit
  53. Installing headunit with built in navi.....
  54. Amp Setup
  55. help with radio/tv
  56. Problem with Alpine Head Unit when using iPod
  57. Amp Help
  58. Reuse equipment from old car or get all new stuff?
  59. 4 OHM Sub. Wanna run it 2 ohm bridged?
  60. Rear defrost button (bulb)
  61. Current Tests
  62. Pioneer AVH-P4000DVD
  63. Ok, so i was installing a double din screen
  64. Question about my amp???
  65. 2004 Civc SI Canada
  66. How long does navigation work?
  67. Will it fit
  68. Headlights flashing
  69. Pioneer FH-P8000BT
  70. Sony CDX-GT820IP
  71. Installing my head unit
  72. Custom door panels
  73. noob question
  74. Aux input questions
  75. Pioneer DEH-P6000UB
  76. Relay help
  77. Trunk volume (stripped) of '04 coupe?
  78. Wheel Well Splash Shield Removal Question
  79. aftermarket alarm goes off at night
  80. Fog Light Relay Problem
  81. fog light question
  82. infinity kappa speakers vs. alpine type r's
  83. Best bang-for-you-buck Mono Amp?
  84. How Much Sound Deadening?
  85. Maybe a cut amp line from terminal
  86. Subwoofer
  87. Amp and Speaker Questions
  88. Speaker size question?
  89. Sun/Moon Roof Button Light
  90. guage backround light problem
  91. amp questions
  92. horn wire
  93. Head light removal help
  94. Rear 6x9s Too Large!
  95. best double din bezel and harness?
  96. HID help plz (searched)
  97. HID KIT W/ TYC PROJECTORS(searched)
  98. Noises in System after amp install..Help !
  99. How to extend battery cables?
  100. iPod direct connect in 04 civic
  101. Question for owners of the Metra Speaker spacer kit????
  102. High Output Alternator Help
  103. SE 05 Radio
  104. What to do with the stock speakers... **Video and DIY Inside**
  105. 2002 civic OEM radio not working
  106. PIONEER AVIC-D3 installation in a 2005 civic EX SE Coupe
  107. g35 retrofit
  108. Coil Stick
  109. dash lights
  110. power door lock actuator
  111. 2002 Honda Civic ES1 4Door Headunit Wiring
  112. D17a2 Ecu Harness
  113. New System
  114. Headlights Blinking...Whats the problem??
  115. AIR HORNS want to instal but few questions
  116. New Radio and Radar integration.
  117. Battery mix n match is it possible?
  118. Need help in getting a new head unit for my DX
  119. location of vss and reverse wire in our 7th gen
  120. Projector Headlight Housing or OEM?
  121. Difference between Neons, LEDs & Cathodes
  122. Multiple power wires or tap into a wire?
  123. How to Determine the Fuse/Wire Size for YOUR Project
  124. Window Problem
  125. Stereo install gone wrong
  126. car alarm post-accident
  127. Fake alarm LED
  128. Problem with Stock Stereo
  129. Gas gauge suddenly stopped working
  130. Dual pro beam angel eyes with hid
  131. Keyless for 2003 LX
  132. my radio issue
  133. Sedan Cluster Help
  134. Factory or Aftermarket?
  135. Coil wiring
  136. Radio Code, HELP
  137. i installed a DEI 529t... couple of q's
  138. Changing stock dim instrument cluster bulbs LEDS
  139. Alpine 9874 install
  140. Weird problems with fuse box
  141. driver's door not grounded
  142. got alternator whine? with system?? someone?
  143. Need recommendations for a new headunit, component speakers, and 6x9s for 02 ex coupe
  144. will this head unit fit?
  145. Viper 479v lost remote!
  146. Suggestions on how to add extra speakers
  147. Sound System Stopped Working
  148. burnt out headlight
  149. what amp do you recommend?
  150. Pioneer FH-P8000BT install with iPod/iPhone integration
  151. HID, stock housings
  152. Anything you'd recommend
  153. stereo/central locking
  154. Help!!!! Amp Wont Power Subs
  155. hooking up the HO alternator to the ELD
  156. leds dont turn off??
  157. connecting headrest screen up
  158. help w/ heater
  159. 2004 civic radio error code
  160. Connector for H4 bulb/headlight
  161. HO Alternator, help on wiring
  162. Oem cd player options
  163. Fog Lights
  164. my rear defrost isn't working
  165. ground noise
  166. grounding the alternator...
  167. SideMarker Ques.
  168. head unit wiring?
  169. Ebay Projector Headlights
  170. alpine type R's installation
  171. adjusting time on stock headunit
  172. Firewall Location : 0/1 Gauge Civic 2004
  173. Anyone know how I could split 1x10 awg to 4x14 awg wires?
  174. 2001 Stock HU - anyone made a aux input without buying and adapter
  175. kinda of a big problem
  176. Need help reading these numbers
  177. Setting up Int. LED lights
  178. one rear speaker louder than the other
  179. No Sound from speakers.....
  180. WTF: Front speakers are louder than Rears
  181. Panasonic cq-vx100u or CLARION VRX485VD
  182. Messed with radio - now no power to radio, PL
  183. Has anyone used the yellow fog lamps from Ebay?
  184. CDT CL-62's for Front Doors
  185. Polk DB651's?
  186. Sub/Amp Install
  187. Kicker Solo-Baric 12" or 15"
  188. Relay Chatter
  189. i need your trunk pics
  190. JL audio W6?
  191. Amp Power help
  192. Which HID
  193. Need Help!! Backup Fuse
  194. accessory caps/plugs?
  195. power control wire
  196. Safest current draw off battery for sub amps?
  197. Please Help rear speakers wont fit
  198. Amp question
  199. car alarm idea
  200. Problem: 900 Watt amp dims front lights
  201. Electrical overhaul needed??.. im F****d
  202. Best Subwoofer Enclosure Tuning Frequency for Civic?
  203. Best Place to ground amp in trunk?
  204. Cheap in dash Monitors
  205. Need help on 05 tailights
  206. power cuts out when driving- help.
  207. Acura EL vs Civic center console
  208. Optima Battery
  209. DIY Big 3 upgrade??
  210. fog lights help... i searcherd
  211. tweeters
  212. alarm help 03 civic lx
  213. My Battery In the Trunk! (56K WHY?)
  214. HELP!!! lights not working, battery draining...
  215. Seat heater fuse
  216. Fog Lights Not Working!
  217. Amp Power Troubleshoot
  218. How easy is it to install new 6x9's in my rear.
  219. ahh. Alpine Type R components wont fit.
  220. Changing Ground of 12V ACC. Plug
  221. ebay fog lights 30 shipped, correction
  222. Power Locks not working
  223. Hazard's and both signals not working
  224. inline fuse holder is needed?
  225. DVD Players
  226. Amp install question
  227. new to the AMP scene, need some help choosing
  228. Input on these boxes
  229. New Head Unit problem
  230. Type of bulbs in center console
  231. Alarm Problems
  232. LED light strips (interior)
  233. Where is the parking signal control for DVD unit?
  234. Post your double Din setup
  235. Sub install help
  236. Tweeters 05 ex coupe
  237. Ebay Armrest
  238. HID TYC Wiring Problem...No power??
  239. Please help!!! removing a 2001 Honda Civic LX stock head unit.
  240. 2005 civic instrument cluster w/mt
  241. TYC Retrofit with TSX-R D2S projectors
  242. keyless entry/power lock issue
  243. Help with sub wiring!!!
  244. 04 Civic Projector Headlights?
  245. Power locks and dome light only work with ignition on???
  246. Trunk Light and Wiring
  247. Radio Help
  248. P.i.e. Hon98-aux
  249. Head Unit Flickering
  250. Component Speakers, Stock HU
