NEED HELP ASAP
Old Aug 25, 2002
juscallmetoyota's Avatar
juscallmetoyota is an unknown quantity at this point
NEED HELP ASAP
OK.. trying to run my power cable through the passanger side firewall... But am I suppose to drill through the firewall.... I can't find an opening. I have a 2002 EX coupe. I've removed all the pannels and pulled the carpet down. I see the velcro piece and cut through that thick sheet of foam. But right behind it, there no opening. Just the firewall. What did I miss?
Steve
Old Aug 25, 2002
JJF's Avatar
JJF
JJF is an unknown quantity at this point
I ran my power wire down by the passenger floorboard,. next to a drain hose or something. I drilled out a hole next to it, and used a grommet. Good luck.
Old Aug 25, 2002
civicvtec1ps's Avatar
Search and Learn
well heres my set up kinda ghetto but oh well works..
and heres firewall..
see all those wires on way left.. just go through there i think . that should work out .
Old Aug 25, 2002
LudlamTheory's Avatar
i boogie for the raindrops
thats a ghetto *** job (through the door)... tape the cable to a coat hanger and jam it through the rubber grommett in the picture above
Old Aug 25, 2002
Search and Learn
yup its ghetto . i was too lazy im going to get my powerwire gothrough firewall soon lol hahah[IMG]i/expressions/laugh2.gif[/IMG]
Old Aug 25, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: civicvtec1ps
yup its ghetto . i was too lazy im going to get my powerwire gothrough firewall soon lol hahah[IMG]i/expressions/laugh2.gif[/IMG][hr]
It's easier to run it through the firewall yakes 30 seconds... Just tape a coat hanger wire to the power wire..feed it through the gromett..
Cheers
Mohawk
Old Aug 26, 2002
Tre's Avatar
Tre
Tre is an unknown quantity at this point
Go with the firewall idea. If you are still having trouble finding the grommet, it's on the passenger side really close to the center console (almost up under the dash). I hope that helps ya.
Old Aug 26, 2002
yah.. I finally figured it out... Thanks for the help.
Steve
