battery/alternator problem, please assist
Old Sep 19, 2002
MVHonda's Avatar
MVHonda is an unknown quantity at this point
to start off, i currently have 2 amps in my car with 780 max and 340 max. the problem started 3 days ago where my girl, "may" have left her the lights on which caused the battery to die, well, the security officer at her work provided a jump start and she was on her way. well, today she is driving back from lunch and the car just stops, and when she tried to re-start, it just stutters, now, i know that the car would not just stop in the middle of the road if it was the battery. would you guys think its the alternator? any ideas fellas? i hope its not the alternator, well maybe, would it be covered under warrenty, and well, i know i have 2 amps, but i could conceal them and just say that it went out on its own, but then again, i changed the head unit though.
Old Sep 19, 2002
Simkin's Avatar
Simkin is an unknown quantity at this point
1120watts plus a head unit on stock electrical system is pretty taxing.
The alternator may have cooked if you didn't upgrade the wiring that goes to it. Our alternators have no fans to cool them off.
And yes, if the alternator is fried, honda will look for a stereo system....hehe, you're better off removing it when you take it to the dealership.
Old Sep 19, 2002
Gryphin's Avatar
00 Hatchback Owner
alternator is shot to hello [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
get a cap. for your amps and stuff , and upgrade your wiring, but before you take it in , take EVERYTHING out related to a upgrade system or else they will not cover it, so basically go back to stock , and make sure to take out any wires you may have installed to run the stuff, because they will see it , but not the thing it hooks up to , and know you took it out
Old Sep 19, 2002
LudlamTheory's Avatar
i boogie for the raindrops
1120 watts of max? thats crap... you could run 1120 watts of rms and still survive on the stock elec system
Old Sep 20, 2002
cheesy9999's Avatar
cheesy9999 is an unknown quantity at this point
yeah dude I have a JBL 1200 watt amp, but then again it's supposed to be pretty efficent, and I don't think I've ever cranked it all the way up. I just got a cap too, pretty tight looking even it doesn't do anything...
If you're interested it's a 1.5 farad cap with a digital voltage display top, by a company called Fusion, check eBay, it's a good deal too, about $85 (none of those $300 PheonixGold caps for me...a cap is a cap...)
Old Sep 20, 2002
Simkin's Avatar
Quote
[hr]Originally posted by: LudlamTheory
1120 watts of max? thats crap... you could run 1120 watts of rms and still survive on the stock elec system[hr]
I didn't say that our systems have a max of 1120 watts, I said it was pretty taxing on the stock electric system.
Running over 1000 watts requires you to upgrade to a thicker gauged cable for your alternator or run a capacitor for your peaks. Otherwise the wires for the alternator will heat up. And when they heat up it, they act as a resistor. Which puts an even greater load on the alternator, and will eventually burn it out under constant load.
Old Sep 20, 2002
and im saying that 1120 watts of MAX power (not rms) requires you to do nothing whatsoever to yyour E-system, not even wire upgrades...
Old Sep 20, 2002
Simkin's Avatar
Ok, well there's really no point in arguing, I mean, tell that to MVHonda with the blown alternator, and how much he can 'REALLY' run.....hehe
Old Sep 20, 2002
mattymatt's Avatar
mattymatt is an unknown quantity at this point
Even if you bring it to honda and they replace it there's a good chance it will blow out
again. I would upgrade the wires if I were you.
Old Sep 20, 2002
Daniel420's Avatar
Daniel420 is an unknown quantity at this point
So there are wires that run to the Alt that need to be upgraded? What are they called? How much...
I'm pretty sure i'll need to get them once I put my JBL 1200.1 in. I jsut don't want to sound like a fool asking at some place... what/where should I ask for those wires.
Old Sep 20, 2002
WhiteRabbit's Avatar
Quote
[hr]Originally posted by: Simkin
Running over 1000 watts requires you to upgrade to a thicker gauged cable for your alternator or run a capacitor for your peaks. [hr]
jbl1200.1 ran at 1200 watts, earthquake 4.3 running at 520 watts. thats RMS power, and anyone who knows either company can tell you how underrated they are.
stock electrical system. still going strong
requires? mowhawk and i went through this, there are alot of myths running around about caraudio. everyone thinks they know something, but please dont use the words "need" or "requires" chances are, you might have stumbled onto a myth. which is exactly what has happened here.
crowtoo
May 11, 2015 06:50 PM
mievil
Apr 28, 2015 11:02 PM
tylerginevan
Apr 27, 2015 12:29 PM
ImmortalEX
Jan 2, 2002 08:45 AM
0100010
Dec 1, 2001 03:27 PM
