suggestions
Old Sep 13, 2002
bake's Avatar
bake is an unknown quantity at this point
suggestions
any for a 3 sub setup which will probably 3 idmax 12's im still not decided if i wanna go with 3 subs or 2, if i get the 2 sub setup im goin with a eclipse da7232 amp
Old Sep 14, 2002
LudlamTheory's Avatar
i boogie for the raindrops
gonna need some serious power for the 3 idmax speakers...
Old Sep 15, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
Quote
[hr]Originally posted by: bake
any for a 3 sub setup which will probably 3 idmax 12's im still not decided if i wanna go with 3 subs or 2, if i get the 2 sub setup im goin with a eclipse da7232 amp[hr]
good luck tring to power that amp. with out stock 70 amp alternator [IMG]i/expressions/laugh2.gif[/IMG]
Old Sep 16, 2002
i smell fried ECU, fried alternator, and dead battery... according to eclipse, that amp draws over 50A on average...
Old Sep 16, 2002
Abstract's Avatar
Abstract is an unknown quantity at this point
Alternator and battery yes, but ECU? I doubt it.
Old Sep 16, 2002
when the power starts getting crazy due to massive draws you get voltage spikes... voltage spikes lead to fried ECU
Old Sep 16, 2002
lilbluecivic's Avatar
lilbluecivic is an unknown quantity at this point
http://www.eclipse-web.com/products/amp/da7232.html
why would you need power upgrades, it dosnt seem like that big of an amp
Old Sep 16, 2002
on the specs it says it draws 50+ amps ... our alternators give us 70 amps, but you gotta subtract everything the car uses, leaving us with about 30 amps of average draw to toy with SAFELY... you CAN go over a bit more, and you CAN peak higher, but i wouldn't reccomend it if you dont wanna run any risks... when you're playing with as much power as that amp draws, you've gone too far... but im not an electrician/mechanic/engineer or anything, this is just the knowledge i've picked up while being here
Old Sep 16, 2002
bake's Avatar
well a new alternator was in the plans b4 getting the amp(s) either a 130 amp or 170 amp alternator was the plan then get the subs, amp, whatnot
Old Sep 16, 2002
ah... ok... then you're fine... as long as your other amps aren't anything outrageously large, a 130 would do you fine...
Old Sep 16, 2002
bake's Avatar
im gonna get a eclipse 32240 for my components and then whatever for subs.....so any new ideas for an amp that would push the 3 idmax subs???
Old Sep 17, 2002
vtechin's Avatar
vtechin is an unknown quantity at this point
If you are concerned about frying things due to large power drawsyou could also get a Yellow top deep cycle ( There is one made for our cars) and a couple caps. These shoud help a little even if you do have a 130 amp alternator.
Old Sep 17, 2002
yellow top = used as a second battery... red top = deep cycle primary battery..., cap = doesn't help strain, adds strain, just removes dimming =)
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
juicetayne
Sep 30, 2015 11:02 AM
anubis62
Sep 27, 2015 12:56 AM
J-Fly
Sep 10, 2015 08:39 PM
