new to ice could use some help!
Old Sep 5, 2002
redcivic's Avatar
redcivic is an unknown quantity at this point
planning in puting in a new sound system, head unit subs and replacin the stock speakers but i need some advice, never done anything this exstensive, mainly on subs a amp selection, if you could give any tips like how do i know wich amp to pick for sertin subs that would be great, also the clasification like someone told me not to get a class D amp cause i will have to use a second battery? and do i really need to replace the stock speakers? any tips and advice welcome but don't flame like i said i'm new here. thanks jason. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Sep 5, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
I suggest you just take an afternoon and read as much as you can in the ICE forum.
Now, if you get a class D amp you WILL NOT need another battery. Man, they really fed you a line there. You can get by with just replacing the fron speakers with some good components and pushing them with an amp. Make sure you are running your sub amp off of pre-outs and don't wire the power and the RCA cables to the sub near eachother.
Hope that helps.
Old Sep 5, 2002
mohawkboom's Avatar
red..email me at dmtp@lycos.com and I'll answer you tonight after work with about as much info as you can handle..in the meantime visit sounddomain.com and termpro.com's forums for ideas and info.
Cheers
Mohawk
IronFist
Sep 25, 2015 07:13 PM
chadds
Sep 9, 2015 05:26 AM
adamdrives
15
Aug 8, 2015 08:53 PM
PiNk
Jul 23, 2002 06:06 PM
BeefMan
Bolt-on Engine Performance
Mar 18, 2002 04:56 PM
