ANL or MAXI
Old Aug 25, 2002
LudlamTheory's Avatar
i boogie for the raindrops
ANL or MAXI
so i was lookin at some amp kits, and i realized that AGU fuses dont really go past 60 amps.... both the amps i'm about to buy have 2 30 amp fuses in them so i was looking into the higher power amp kits and came across both ANL and MAXI fuses... any upside or downside to either?? ANL seems to be a fraction more expensive...
Old Aug 25, 2002
mohawkboom's Avatar
Well if your not going to upgrade your alternator just use a 60 amp AGU Fuse [IMG]i/expressions/face-icon-small-smile.gif[/IMG].. that way you'll never overdraw. Use an ANL fuse than have a much lower passthrough resistance..
Cheers
Mohawk
Old Aug 25, 2002
will a 60 amp AGU blow with a kicker kx600.4 (only running 300 watts because it'll be @ 4 ohms) and a jbl bp600.1 @ 1 ohm?
Old Aug 25, 2002
mohawkboom's Avatar
Nope it shouldn't blow.. My Brother runs an old PPI2600.2 and a PP2400.2 off a 40 amp AGU fuse...never blew it..
Old Aug 25, 2002
while were at it, 4 gauge or 1/0
Old Aug 25, 2002
mohawkboom's Avatar
Unless your pulling 100+ Amps 4 guage..
Old Aug 25, 2002
4 gauge amp kit w/ 20 ft of 4 ga wire, ANL fusebox w/ 80 amp ANL fuse, RCA cable, remote wire, 1 in 4 out AGU fused distribution block, and all the little connectors for 38 bucks on autotoys.com... i guess i'll just switch the ANL holder with my existing AGU fuse holder
Old Aug 25, 2002
mohawkboom's Avatar
Sounds decent..but be sure to buy better RCA's the one's included in kits are usually unshielded and crappy
Old Aug 25, 2002
yup, i've already got some monster cable RCA's from my home stereo... i've got this box at home full of random cables...
DetailersDomain
Detailing
Dec 29, 2011 10:26 AM
SinaloaCivic
Jan 5, 2006 01:51 AM
D17thgen
Mar 25, 2005 02:12 PM
Malakigh
Jan 24, 2005 05:19 AM
greg2k1
Jun 22, 2002 11:40 AM
