How do I do this???
Old Sep 22, 2002
LuvDatCivic's Avatar
LuvDatCivic is an unknown quantity at this point
How do I do this???
How do I check if their is a short in my stereo power wire??
Old Sep 22, 2002
Abstract's Avatar
Abstract is an unknown quantity at this point
get a test meter and see if it gives you continiuty between the power wire and ground.
Old Sep 22, 2002
What kind of test meter? Would a stander voltmeter work?
Old Sep 22, 2002
Abstract's Avatar
most multimeters have someting that can test continuity.
Old Sep 22, 2002
Abstract's Avatar
another trick would be to take a 12 v led hook the positive up to teh fuse box and test teh ground of teh led to your radios power wire, that will tell you if it is grounding out.
