Blinkers not working?
Old Sep 9, 2002
form3hide's Avatar
form3hide is an unknown quantity at this point
Alright, I took out my whole headunit console in order to get some custom stuff done to it, woo!
Anyways, my blinkers do not work anymore because of it. I once read that when you unplug the hazard button then this happens? What's the truth to it, or did I simply somehow just blow a fuse?
Old Sep 9, 2002
CivicPunker17's Avatar
CivicPunker17 is an unknown quantity at this point
check to make sure your hazard buttons plugged right, that should fix your problem.
Old Sep 9, 2002
form3hide's Avatar
It's not plugged in at all. That whole console is removed at the moment. I'm driving with nothing hooked up, headunit/hazards/air controls...
Old Sep 9, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
I think I know what's up...
When you have the hazards disconnected, you are openning the circuit with your blinkers. Once you reconnect them, you will complete the circuit and your blinkers will work again.
I don't know if you've ever taken your door panels off but it's similar to that... say you took your passenger side door panel off and disconnected the wires that go to your window button... now say you wanted to roll your window up/down after you've done that from the drivers side door... it won't work cause you disconnected the wires that complete the circuit to your window controls.
I could be wrong but that seems to me to be what the problem is so once you reconnect it you should be good to go.
Old Sep 10, 2002
WhiteRabbit's Avatar
nope, your completely right, litespeed. unplug the hazard switch, blinkers dont work. will go back to normal when you plug them back in.
MyCivic
Electrical
Oct 28, 2021 11:06 PM
ORskier
May 3, 2015 12:54 PM
0100010
Aug 6, 2008 09:22 PM
Hondasport01
Dec 17, 2001 01:53 PM
TexazMane
Dec 10, 2001 08:31 PM
