is this box size correct
Old Aug 27, 2002
srfdog88's Avatar
srfdog88 is an unknown quantity at this point
I had a box made for at tweeter for my jl 10w3. my question is the box sizeis 17 inches wide, 15 and 1/2inches tall and 8 inches deep. is this the right size. i am powering it with an xtant 3001 amp. is this amp sufficient to power the sub. thaks
Old Aug 27, 2002
Tre's Avatar
Tre
Tre is an unknown quantity at this point
If that box is sealed, then it is most likely a tad too big. Taking into account thickness of the wood (approx. 1/2 inch), that box is right at 1 cu. ft. The spces for that speaker according to the JL Audio website call for a sealed enclosure 0.6-0.9 cu ft. If that box is ported, then it may be okay (kinda small after the displacement of the woofer). Ported specs are 1.0-1.5 cu ft. But if it sounds good to you, then that's all that really matters. That amp should be more than adequate to power that speaker.
Power ratings:
JL 10w3v2 : 300 rms
Xtant 3001 : 150 rms x 2 = 300 rms[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Aug 27, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
i figured it out to be about .86 cubic feet before displacement. so its about right for a jl
Old Aug 27, 2002
LudlamTheory's Avatar
i boogie for the raindrops
if its 3/4 inch wood (as it should be) then its 0.81626157407407407407407407407407 cubic feet
Old Aug 27, 2002
Tre's Avatar
Tre
Yeah, it should be 3/4 in wood, but alot of shops like to skimp on that and use the cheaper 1/2 wood. I dunno what the boys at Tweeter use, but I do know that alot of boxes at Best Buy here in Atl. use 1/2 in.
Old Aug 27, 2002
cheap bastards... i wanted to use 1 inch on my custom trunk, but the store only had 3/4 inch MDF
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
