JBL BP300.1 Mono Amp
Old Sep 18, 2002
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
anyone have experience with that amp? its up in the market place for 100 bucks. im planning on pusing 2 12 inch subs. probably jl w3's
Old Sep 19, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
That's a mono block amp right? If I remember, those mono block JBL's are good down to 1 ohm. May not be enough power. If you get the 4 ohm 12W3's then you can wire them in parallel to a 1.5 ohm load. That'll pull a ton of power outta that amp and you'll be bumpin pretty good. Though I've been informed (and not entirely sure if it's true) that at lower resistences you THD increases. Then again, if you're running a mono block the THD is probably already high. I think that amp puts out 300 x 1 @ 2 ohms? Is that right? If it is then you might want something a little bigger. Two 12W3's take 500 watts RMS together.
Old Sep 19, 2002
yeah its 300x1 at 4 ohms. its continous power handling is 250 watts. would 150 watts continous be underpowering it?
Old Sep 19, 2002
LudlamTheory's Avatar
i boogie for the raindrops
only the 600.1 and the 1200.1 are down to 1 ohm.. the 300.1 only goes down to 2, but the 600 and 1200 have no power increase between 1 and 2 ohms
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
