question about amp wiring.
Old Sep 15, 2002
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
k guys i got a question about wiring the amp.....what i got:
jensen 2 channel amp
precision power 4 channel amp /w 1 channel broken.
1 subwoofer
is there any way i can use 2 channels from the ppi to power the front and bridge the other 2 channels, since 1 channel is broken... to power the sub...
then use the jensen 2 channel to power the rear speakers...........
pls tell me this works...... or u guys got any other ideas?
Old Sep 15, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
Well... I would give it a shot but I don't think it'll work. When you bridge 2 channels together, you are taking a positive from one channel and a negative from another channel. If one channel doesn't work then you will only be running one positive or negative to your sub which won't do you any good. Maybe just your positive or negative terminal is broken on that channel and the other terminal works. I would just test it and see if it works.
Old Sep 15, 2002
WhiteRabbit's Avatar
you can bridge the two good channels if only one is broken
Old Sep 15, 2002
BlueTroll's Avatar
i'm using the jensen to power the sub right now......... i want to have all four speakers to have stereo..... but if worse comes to worse.... i'll probably just run the rear in mono...... i'll just goto my installer and ask him if he could do this....... cuz i bought the amp from my friend and he said u can bridge 1 channel and the broken channel and run it mono.....
Old Sep 15, 2002
ideally you want to be running your rearfill mono anyways.
Old Sep 15, 2002
BlueTroll's Avatar
hum........... really?... its supposed to be in mono?
Old Sep 15, 2002
not "supposed" to be in mono, just that theoretically you get less destruction of your stage by going mono.
theoretically...
edit: just like theoretically, rearfill should only be playing midbass frequencies, shoul dbe on very low power, and should not be located low. supposed to be that way? not realy, but its just the theory for an ideal rearfill setup.
Old Sep 15, 2002
BlueTroll's Avatar
alrites.... coools..... so i trust u guy...... i'm gonna run it mono....... but ONLY..... if my great idea b4 doesn't work....... thx dude...
redcloud
25
Aug 12, 2015 01:23 PM
sch2cm
Jul 21, 2015 09:58 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
