alpine cda-7894 problem
Old Sep 16, 2002
pimpcivic's Avatar
pimpcivic is an unknown quantity at this point
sup, i just got my cda-7894 installed at circuit city, mainly b/c they had a deal on free xm installation so i figured i might as well.....well i can't see the display during the night time (yes i kno it is partially the way the car is designed). Well here is where it gets funny, while my mom was driving my car, she said the head unit all of a sudden got real bright to where she could see it fine for about 30 secs. then it went away. Then she said it happened again a little bit later.
so i looked under the hood (im not real good with wiring so i could be wrong) but it didnt look like they connected it directly to the "+" terminal on the battery like the alpine must be connected, or it will short out eventually b/c i am using the internal amp.
do u think that could be the solution to my display problems???
any thoughts would be great.
thanks
Old Sep 16, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
Well, the connection the battery terminal should have nothing to do with that. I'm assuming that your HU is always on, only the brightness of the display changes. It's probably the connection with the dimming wire behind your HU.
Do you always drive with your headlights on?
Old Sep 16, 2002
vtexcivic's Avatar
vtexcivic is an unknown quantity at this point
hey i have the same HU mine works fine i dont think it involves the battery they probably messed up on the harness
Old Sep 17, 2002
Samson's Avatar
Samson is an unknown quantity at this point
I have the 7893 and it is also supposed to be hooked directly to the battery but its not and it works fine. But on the 7894 theres a blackout function to where u can turn off the display to "reduce power consumption" maybe this is something u can check into.
Old Sep 17, 2002
Abstract's Avatar
Abstract is an unknown quantity at this point
It doesn't need to be direct to the battery, you should be fine, something else is up
Old Sep 17, 2002
pimpcivic's Avatar
well if u are using the internal amp, the direct connection to the batter is a good idea......i dont want to risk anything happening to it.........what do yall think the problem could be, i kno part of it is the car, but i cant see a thing.....i kno it is supposed to be brighter than it is right now
Old Sep 17, 2002
LudlamTheory's Avatar
i boogie for the raindrops
my thoughts on the subject: my HU is hooked up to the illumination on the car, as should they all be, so when you turn the little **** by the gauges down to reduce the light from your gauges, the HU also dims... make sure that **** is all the way up, if not, make sure the illumination wire is hooked up correctly, or, it could be a defective HU
Old Oct 31, 2002
ziggyziggy69's Avatar
ziggyziggy69 is an unknown quantity at this point
why are u guys not hooking up the + terminal to the battery? wouldnt it be better and also retain ur warranty?
Old Oct 31, 2002
fatboy's Avatar
fatboy is an unknown quantity at this point
ummm....I don't know bout you, but I got a pioneer unit and there's a function called "dimmer" (i think thats's what it's called [IMG]i/expressions/face-icon-small-confused.gif[/IMG] ) . This function works directly with the parking/head lights, so the headunit AUTOMATICALLY dims whenever you have your lights on. When your moms said that she temporarily saw the unit "nice n bright", she had probably just gotten in the car BEFORE turning the lights on. When she saw it bright again later, it was probably when she was turning the car off and had turned the headlights off. I am willing to BET that that's your problem. DAMN I'M GOOD!!! I should be a detective or something. You can thank me later by the way..... FATBOY *** < PIMPCIVIC
Old Oct 31, 2002
Ed's Avatar
Ed
Then why can't he see it at night normally?
Old Oct 31, 2002
Firefly's Avatar
Firefly is an unknown quantity at this point
The Alpine 7893 and 7894 need a direct connection to the battery if you're running the internal amp due to its high current draw. That amp pumps out 27W RMS/60W MAX and it's one of the most powerful internal amp among all the units out there. The unit will run if you don't do it but you might run into problems like you described or blowning your panel fuses all day.
If they didn't run the direct cable for you just get an amp power kit and run the cable yourself. Even some of the "authorized" Alpine dealers don't do that when they install the 7893/94.
Old Oct 31, 2002
fatboy's Avatar
Quote
[hr]Originally posted by: Ed
Then why can't he see it at night normally?[hr]
because he has his lights on at night, and the radio DIMS the display automatically. I don't think I could have been any more clear in my previous post
Old Nov 7, 2002
pimpcivic's Avatar
it was daytime the lights were never on..just to let u kno
OPGForce
Feb 7, 2002 09:43 AM
SLeePeR012
Jan 7, 2002 12:24 AM
delacampos
Transmission
Jan 2, 2002 02:06 PM
wishihadavtec
Dec 30, 2001 05:33 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
