PDA
View Full Version : General
  1. help
  2. Who can help
  3. stay away from this vendor!
  4. Weird sound coming from under hood on driver side
  5. Advice Needed: Selling My Non-Operational '05 Civic - Restore or Sell As-Is?
  6. 2001 automatic ex wire harness issues
  7. 2005 D17 automatic shuddering, crazy dash lights, stalling.... No codes
  8. ep3 anyone know what this part is called?
  9. 2003 Civic Si (EP3): Recommendations for good Honda mechanics in Michigan?
  10. unknown part
  11. 2003 civic coupe vibration when a/c on..and in reverse
  12. Best ways to free up power steering pressure line frozen connection
  13. is there a haynes manual in pdf anywhere?
  14. Going to junkyard need estimate [solved]
  15. Intermittent shake At HWY speed and braking
  16. What’s is this/where does it go?
  17. Interchangeable part's
  18. Engine knocking
  19. Cap Missing? Under air intake box.
  20. 2003 Civic Vtec Se sport
  21. Flooded Vehicle
  22. Plz help
  23. Where this sensor located? Solved*
  24. 5 speed rocks back and forth in 1st [solved]
  25. 7gen manual?
  26. Gas Cap Won't Open - Tried the Common Fix
  27. Tensioner bolt length
  28. Any tutorial requests?
  29. P0118 & P1298 OBD Code
  30. Attention Dickheads
  31. New to me 2002 Civic Coupe, some questions
  32. Cleaning engine bay?
  33. Civic 2004 engine remote control car noise
  34. Crazy Loud Rattle
  35. Acceleration problem
  36. 05 civic ex 2dr redlimes at 4 rpm??
  37. a few questions
  38. Poor Acceleration P1298 Code [solved]
  39. Finding Parts for Wire Management
  40. Airbag advice
  41. P1457 code after vapor canister vent solenoid replacement
  42. Tow car with tow rope
  43. Key stuck in Ignition
  44. EVAP p1457 CVS valve easy fix
  45. 05 1.7L whine noise on acceleration
  46. 2002 Civic noise when turning steering wheel
  47. 2001 Honda civic EX Engine or trans issue? Help.
  48. Check engine flashes when I hold trip reset to clear maint req’d
  49. What's a bad condition 2005 Civic worth?
  50. Driver side door doesnt unlock and other issues
  51. Front jacking point question
  52. Whine/squeal sometimes while in gear over 1500 RPM
  53. Leak
  54. I just got a free em2 with 250k what should I start fixing
  55. Common issues to look for
  56. Unknown problem with my 04 civic, need help
  57. Whine/groan on first acceleration
  58. LAF sensor P1166
  59. 2004 Civic Needs Work - cost?
  60. 2005 Acura EL M/T Shaking
  61. Mechanic Recommendations
  62. Oil on floor after car on stand overnight..??
  63. 2005 Honda Civic LX shaking
  64. my ol' civic on it's last chance of life...
  65. Help...cruise control module?
  66. Restoring my 2001 honda civic LX
  67. AC Alternator belt issues.
  68. Hhaving a meltdown. My car's been on jacks for over 3 months
  69. 113,000mi civic
  70. Slave Cylinder and Bleeding Help Please (2004 Honda Civic)
  71. P1457 and advice
  72. Replace Engine Advice
  73. unlock the steering column.
  74. Shudder at 35-40mph
  75. Squeaking noise on Honda Civic 2001 Lx
  76. Car Caught Fire
  77. Noise under acceleration
  78. Steering wheel turns 360 degrees
  79. Motor mount pieces
  80. 02 Civic Si Leak on Top of Fuel Tank
  81. Moisture inside headlight & also boot under spare wheel.
  82. Does The Radiator Cap Need To Be 1.1 Bar
  83. honda civic hood won't close, the push/release button at driver side is loose
  84. Best place to buy used D17A1 motor
  85. Ignition and steering wheel locked.
  86. Coolant leaking out AC drain tube
  87. Fuel Tank -2003 civic lx 4dr
  88. Battery light flicking [video]
  89. Clattering noise when idle, temporarily goes away when I turn wheel?
  90. no pressure when open the gas cap
  91. 2005 Hybrid IMA issues after clutch job
  92. Knocking upon accel/decel.
  93. Does this look like reasonable pricing ?
  94. Tiny Blue clips is door panel?
  95. Should i salvage or can i fix?should i
  96. Hit a Rock with Suspension
  97. Secondary 02 sensor has 24volts ? Wtf
  98. The right tape for my window, and removing the Wrong tape !
  99. UNCOMMON engine vibration problem
  100. Canadian built, US made, California ULEV certified
  101. Please help. Lost car key. What do I need to get the car going?
  102. Automatic 02 civic multiple issues garages cannot diagnose
  103. Weird sound when revving or under load.
  104. OBD2 Communication Error After Belt Broke
  105. Ran over debris in road broke fuel tank straps - won't start
  106. Trouble finding body parts
  107. She died while driving
  108. Engine replacement
  109. two DTC Codes?
  110. Why is fuel pump clicking on 2005 after battery change?
  111. Tps
  112. 2001-2003 headlight adjustment in california
  113. VSS - Troubleshooting
  114. The lights are intermittent on the auto shifter and the rear window defogger switch
  115. Car Jack (Help)
  116. Head Gasket recall
  117. Maintenance Required at 132K Miles ???
  118. When to check the oil level (cold, running, after running)
  119. I'm looking for a honest mechanic
  120. which is crucial, Solenoid Gasket, Strut or Compliance Bushings
  121. Placement of jack and jack stands?
  122. 02' 1.7 odd hesitation
  123. Is it necessary to idle an EM2 at start up?
  124. Lemon Law???
  125. 80,000 Miles
  126. Car jerks just before stopping
  127. squeecking noise when i reverse..
  128. 5w-20 or 5w-30
  129. Key won't come out of ignition unless battery disconnected!
  130. Service Bulletins?
  131. buzzing noise from front passenger side
  132. my warranty is finaly up
  133. Strange Sound After Startup?
  134. Sort of worried...
