General Post issues, questions that are not in the other sub-forums
Moisture inside headlight & also boot under spare wheel.
Old Jan 19, 2020
SynysterDan's Avatar
SynysterDan is an unknown quantity at this point
Hi there,
Well Basically I cleaned the front of the headlights today but I noticed a fair bit of moisture inside the light. Does anyone have any tips on how to stop moisture from getting in?
I don't have a problem taking them off. I will probably do it tomorrow as I have a 160 mile night trip to do. I read somewhere that you can take it out and fill it with water to see where water is getting in?
I don't really want to but new lights if possible.
Also I have a puddle under my spare wheel in the boot. It's quite a lot of water in there. Is it probably the boot seal? tia
Old Jan 19, 2020
Colin42's Avatar
Re: Moisture inside headlight & also boot under spare wheel.
You would have to separate the lens from the housing and reseal it, personally I would live with it or get new ones.
truck seal could be bad or may be the flap behind the bumper below the gas door
Old Jan 20, 2020
Ok thanks. It has rained a lot in the last week so I will see if it clears then go from there.
Old Jan 20, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Trunk lid light housings can leak water as well.
Old Jan 21, 2020
Yeah that's a good shout because when I had another quick look there was water near the back of the light.
Old Jan 21, 2020
Colin42's Avatar
If you have a helper one of you can sit in the trunk with a flashlight and the other is on the outside with a hose, spray all around and figure out where the water is getting in
YYZRush747
Exterior
37
May 10, 2019 06:22 PM
Deano3110
Mar 31, 2018 03:59 PM
alan9069
Nov 17, 2013 09:32 AM
JayeDee369
Buy, Sell, & Trade - Archive
Dec 6, 2009 09:27 AM
gearbox
Nov 30, 2009 12:33 PM
