8th Gen 2006 - 2011.
Boot under panel has water in it
Old Mar 31, 2018
Deano3110's Avatar
Deano3110 is an unknown quantity at this point
So went in my boot today to find a puddle of water plus rear passenger seat belt wet when extended seats all dry checked usual lights seals any one else had this prob cheers only had car 1 month so think its back on warranty
Old Mar 31, 2018
mhammond1127's Avatar
mhammond1127 is an unknown quantity at this point
Re: Boot under panel has water in it
So, I do not own a 8th gen, I own a 7th gen but I’m genrally pretty good with working and dealing with Honda’s of any model. It all sounds like a seal to me. Mine has bad door seals so sometimes I end up with water coming inside the car right under the door speaker. As far as the boot is concerned that could be many things, either needs to be replaced or the Rubber could have gotten a slight hole or crack in it allowing water in but no way out. Hope that helps.
Old Mar 31, 2018
Colin42's Avatar
Dry everything, and then spray the entire area with a hose, along the edges of the trunk, back window, and the doors. Should show where the leak is. If you can have a light and a camera recording in there. I thinks there's also a vent in behind the bumper, that may be letting water in.
Old Mar 31, 2018
Deano3110's Avatar
Cheers buddy I'll do that and yes I forgot about the vent if no joy they can have the hassle on warranty buy it' 60 mile round trip so I'll give it a go first
laack
Aug 25, 2010 12:31 PM
BJanzen
Nov 24, 2008 09:08 PM
Yoshiemaster
Dec 5, 2005 07:27 PM
