General Post issues, questions that are not in the other sub-forums
unlock the steering column.
Old Jun 2, 2020
Phillip Lloyd's Avatar
Phillip Lloyd is an unknown quantity at this point
I have a civic that has been junked the motor is bad. Not needing it ive lost the keys. I don't need the car to run. I just need to beable to move it to another location on my property. What can I do? Thanks in advance.
Old Jun 2, 2020
BrotatoChip's Avatar
Super Moderator
Re: unlock the steering column.
Remove the ignition cylinder and the steering wheel will turn as normal. Take the trim pieces off of the steering column. The ignition assembly is held on with two bolts on the top. These bolts break during installation though so there is no hex head or anything on them. You will have to cut them off, cut a notch in them and then use a flat-head screw driver, or use a screwdriver and a hammer to get the bolts to loosen.
Old Jun 3, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
If you don't need to steer it and just want it in Neutral (assuming an AT here), you can use the shift interlock release under the tab at the shift console.
vicxblood
Jan 20, 2018 12:40 AM
qlitten
Jul 21, 2015 03:12 PM
hondaruss
Sep 10, 2008 03:29 PM
fakitzjason
Oct 14, 2007 10:39 AM
Black04ex
Nov 25, 2005 01:44 AM
