General Post issues, questions that are not in the other sub-forums
Secondary 02 sensor has 24volts ? Wtf
Old Jun 21, 2019
CivicBlue05's Avatar
CivicBlue05 is an unknown quantity at this point
I unplug the secondary 02 sensor on my 05 ex and it says 24 volts?? I hook it up and now I have a high voltage bank 1 sensor 2 check engine light code. Not sure why it has such high voltage. No breaks in the wires that I can see. I'm not gonna replace the sensor just to fry the new one if 24v can damage it. I thought it should have been 12v.
Old Jun 21, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Secondary 02 sensor has 24volts ? Wtf
You sure you are reading the voltage correctly? That is way too high. Should be around 0.3 V to 1 V. Check for poor connections or loose terminals at sensor and PCM. Check for an open in the wires between sensor and PCM. As a last resort, the PCM may be faulty.
Old Jun 21, 2019
Slumpertcivic's Avatar
Just saying... are you sure your meter was not showing 2.4volts? Air fuel sensors work backwards so a out of range “low voltage” would be considered “high”
Old Jun 21, 2019
Whops, just saw it’s your secondary sensor so that’s just a O2, not A/F
hollyjosh2k3
Jul 28, 2018 09:36 AM
smmack15
Bolt-on Engine Performance
Jun 18, 2014 11:59 AM
tide55
Dec 19, 2013 11:37 PM
sekhonjatt
Jun 24, 2013 08:09 PM
Slow Gold
Feb 12, 2006 12:58 PM
