o2 sensor problems
Old Jul 28, 2018
hollyjosh2k3's Avatar
hollyjosh2k3 is an unknown quantity at this point
o2 sensor problems
Just bought a work car 03 civic hybrid. Check engine light was on when i checked it out had my scanner with me and pulled one code, p1166 02 sensor heater malfunction.
I bought the car, get home test the o2 sensor with meter and is in fact faulty. after much research, found the correct sensor to be 234-9005. bought, installed, cleared code and now i get this code.
P1158 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS- Terminal Low Voltage
anyone else have this issue?
thanks in advance!
I see a last resort being reprogram the PCU
Old Jul 28, 2018
Slumpertcivic's Avatar
Re: o2 sensor problems
We see people all the time that received a “Denso Compatible” sensor that did not work worth a hoot.
True desnso will come in a denso box and have denso printed on the sensor and even then you still might have received a bad one.
Curtman
Jan 11, 2019 03:32 PM
smmack15
Bolt-on Engine Performance
Jun 18, 2014 11:59 AM
tide55
Dec 19, 2013 11:37 PM
p7C
Oct 17, 2012 10:18 PM
BrickM
Sep 27, 2012 02:25 PM
