General Post issues, questions that are not in the other sub-forums
Key stuck in Ignition
Old Oct 17, 2021
IfollowUdie's Avatar
IfollowUdie is an unknown quantity at this point
Exclamation Key stuck in Ignition
I own a 2005 honda civic ex coupe with 185K miles (Engine and tranny are both 60K). My key is stuck in between 1 and 0. I hear the click that unlocks the shifter, I'm able to drive it in all gears fine, but the key won't come out. I've tried unplugging the ignition, unhooking the battery, WD40, jiggling the steering wheel, and making sure it is 100% in park. Please someone help throw some ideas out there. I don't want my car stolen as I don't live in the best part of town.
Sorry if this isn't the right thread to do this on. Please move accordingly.
Old Oct 17, 2021
Colin42's Avatar
Re: Key stuck in Ignition
Potentially the pins are jammed in the lock cylinder.
if you remove the column trim and look at the cylinder you should see a spot where you can stick a pin in and with the key rotated to on the lock cylinder should slide out
Old Oct 17, 2021
Can you get a pic or something? I have no idea what anything in it is supposed to look like in the first place lol
Old Oct 17, 2021
Colin42's Avatar
Found this video (didn't watch it) should be helpful.
basically pull the covers off the steering wheel (4 screws) looking at the ignition cylinder you should see a little hole to stick a paper clip, pin, etc in.
Key needs to be in the on position in order for the cylinder to come out.
Old Oct 18, 2021
Thank you so much!!! I'm gonna try that in the morning. Just gonna trust my apartment complex not to steal my car
Doolittlehyena
Nov 23, 2020 02:32 PM
GotZoom76
Mar 19, 2018 06:33 AM
PHILLYCIVICROB
Aug 21, 2006 03:58 PM
gqsang
Feb 13, 2002 08:21 AM
