General Post issues, questions that are not in the other sub-forums
Intermittent shake At HWY speed and braking
Old Apr 22, 2023
civicvibrations's Avatar
civicvibrations is an unknown quantity at this point
Hello all. I make a semi long drive every weekend. Past two weeks, after the first 20 minutes of driving with no issues, I'll hit a 20 min stretch at speeds going 65 plus where I get a pretty good shake/vibration/helicopter thump sound throughout the car and steering wheel. It continues when decelerating and there is a pulsing in the brake pedal when applying them.
After a few iterations of accelerating and braking at lights for that 20 min stretch of time, it just stops and doesn't happen again for the rest of my hour and a half drive. I replaced the brakes and rotors 7 months ago, and I can't understand why a motor mount, caliper or transmission will be fine for 20 mins, act up for 20 mins, and then be fine for an hour and a half.
What the heck could this be?
Old Apr 23, 2023
Re: Intermittent shake At HWY speed and braking
rotate tires around, see if sound moves
Old Apr 23, 2023
Will do.
I was reading around a bit. Can the ABS be activating while on the gas pedal? And that would cause the pulsing in the brake pedal when I do eventually apply them? There's no light and I really don't have a prior experience with ABS activation, so I don't know how it's supposed to feel.
Old Apr 23, 2023
Colin42's Avatar
Probably a warped rotor, maybe a sticking caliper
Old Apr 23, 2023
Originally Posted by civicvibrations
Will do.
just get car over wet grass and stomp on brake pedal, you will quickly find out how it feel
Even a worn out tie rod can make vibrations during braking (wheel will start moving)
conspiracy90
Jun 7, 2023 01:01 PM
Mikey91
Jan 13, 2018 04:51 PM
whatsaricer
Brakes
19
Oct 4, 2011 05:17 PM
JALO03CIVIC
Mar 23, 2010 10:05 AM
stevanrk
Wheels and Tires
Jun 29, 2008 12:28 PM
