General Post issues, questions that are not in the other sub-forums
P0118 & P1298 OBD Code
Old Apr 20, 2022
brbforever's Avatar
brbforever is an unknown quantity at this point
Good Evening,
I recently replaced the ECT sensor on my 2002 Honda Civic EX Coupe, but my OBD-II Scanner detected two codes (P0118 and P1298). The check engine light disappeared and the sensor reads the temperature on my dashboard. Is there other options or methods to solve P0118? Should I clear the fault code? I hear it may fail future smog tests. Is this true?
As for P1298, I purchased a Genuine Honda 38255-S5A-003 Electronic Load Detector Unit and hope it will clear the code. Any feedback is appreciated.
Old Apr 22, 2022
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: P0118 & P1298 OBD Code
Check for poor connections or loose terminals at the ECT sensor and the PCM.
Use only an OEM ECT sensor.
Check for an open in the wire between the PCM and the ECT sensor.
Check for faulty PCM.
Check for poor connections or loose terminals at the ELD and the PCM.
Check fuse #4 (10A) in the Under-dash Fuse/Relay Box.
Repair an open in the wire between the fuse and the ELD.
Repair an open in the wire between the PCM and the ELD.
Repair an open in the wire between the ELD and ground.
Check for faulty ELD (or alternator).
Got rodents chewing wires?
Old Apr 22, 2022
NDNV's Avatar
Is P1298 code safe to drive with? - Honda Civic Forum (civicforums.com)
JAE
Jul 28, 2018 08:32 AM
Hayden_Fourroux
Nov 16, 2014 09:32 AM
carlosdee
Sep 12, 2014 10:48 PM
civ_nate
Jul 19, 2007 10:13 PM
gilloz
Buy, Sell, & Trade - Archive
Oct 2, 2006 10:28 PM
