1998 civic ex error code fuelsys1 ol fault from autel scanner
Old Jul 26, 2018
JAE's Avatar
JAE
JAE is an unknown quantity at this point
Hi all,
new member, need advice
Can reset check engine light, but comes back next key cycle.
Advice
Thanks
Last edited by JAE; Jul 26, 2018 at 07:14 PM. Reason: want to send to correct forum
Old Jul 26, 2018
Re: 1998 civic ex error code fuelsys1 ol fault from autel scanner
Post moved.
Welcome to the forum!
What's the OBD2 fault code? (code in the standard "Pxxxx" format)
Post the freeze frame data too if your scanner will show it.
Old Jul 28, 2018
JAE's Avatar
JAE
P0135
Thanks for the assist, if it is an O2 sensor, can they be cleaned, or needs to be replaced
Old Jul 28, 2018
The definition of that code number is "heater circuit fault" (HO2S, B1S1)
Ohm test the heater portion of the sensor, Replace sensor if it is out of spec
ajpats26
Electrical
Apr 22, 2019 06:02 PM
Noobie1234
Jan 29, 2017 06:01 PM
carlosdee
Sep 12, 2014 10:48 PM
lollygagger
Jan 6, 2011 10:55 PM
civ_nate
Jul 19, 2007 10:13 PM
