OBD II code
Old Jun 6, 2010
lollygagger's Avatar
Person
lollygagger has a spectacular aura aboutlollygagger has a spectacular aura about
OBD II code
Hey guys, I have an 04 Civic coupe EX, that I just purchased. Noticed the maintenance light was on, had it scanned and the P0135 code. I just replaced it, with a universal 4 wire oxygen sensor. I wired everything correctly, I assume, as the instructions were a little shoddy. Now I get the P2252 code. Any ideas on what this is?
Thanks!
Old Jun 6, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: OBD II code
I can tell you what the code is but I can't tell you what it means.
P2252 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS- Line Low Voltage
Old Jun 6, 2010
greeen01civic4d's Avatar
Re: OBD II code
thats what happens when u use a universal, it fails.
Old Jun 6, 2010
Re: OBD II code
yea.. I definitely spent bank buying OEM O2 sensors..
Old Jan 6, 2011
michigan98gt's Avatar
michigan98gt is an unknown quantity at this point
Re: OBD II code
I had same issue. Now I get the P2252 code. This is the replacement sensor I purchased:
http://www.carpartswholesale.com/v5/?N=0&Ntt=ARBH960907
What do I do now and is this a problem I should worry about for now?
Thanks for the help!
Old Jan 6, 2011
lazlong's Avatar
Re: OBD II code
Bite the bullet and buy one from here: http://www.hondapartscheap.com/southbay/jsp/home.jsp
Civic15
18
Sep 19, 2017 07:48 PM
Dangerousjordan
Jul 30, 2015 11:19 AM
jessica19699
Jul 29, 2015 05:51 AM
Green02civic
Jul 27, 2015 10:48 PM
EliseKStewart
Jul 15, 2015 11:11 AM
