General Post issues, questions that are not in the other sub-forums
Gas Cap Won't Open - Tried the Common Fix
Old May 13, 2022
Civic_broken's Avatar
Civic_broken is an unknown quantity at this point
Question Gas Cap Won't Open - Tried the Common Fix
The gas cap to my 2005 Honda Civic won't open when I push the lever, I've been opening it from the trunk for a while now and it's not really a problem but I still want to fix it. I just finished installing the Dorman Repair Kit where the cable assembly is known to break, but it didn't work. It seemed a little loose and I thought maybe I could zip tie it tighter and maybe that would do something. If that doesn't work what should I do next? Inspect the whole cable? I noticed in the trunk there's a splitter type of device that splits the input cable and sends one to the trunk release and another to the gas cap release, is that known to fail? Any and all options are much appreciated, thanks.
Old May 14, 2022
Colin42's Avatar
Re: Gas Cap Won't Open - Tried the Common Fix
Cable might be broken elsewhere, or the Dorman part might be junk/broken/installed wrong.
I just replaced the cable with a new one from Honda, it wasn't too expensive. Took the opportunity to replace the rear speakers as well since I had 90% of the parts off to get the rear deck off.
azi90
Interior
Dec 13, 2019 06:00 PM
ctopher
Sep 7, 2006 07:58 PM
Genevieve
Jun 5, 2005 03:53 PM
spoonEM
Apr 21, 2005 11:31 AM
justheman
Dec 30, 2002 06:43 PM
