Trunk / Gas Lever Cable snapped--HELP
Old Aug 29, 2006
ctopher's Avatar
ctopher is an unknown quantity at this point
I pulled into to fuel up the other night and when I went to pop my gas door, the lever became tight and then the cable snapped.... Now i can't get into the trunk or open the gas door using this lever. I had to open the trunk with the key and fold back the inner material of the trunk, reach in behind and get the gas door opened that way.......Has anyone ever replaced this cable and how difficult is it?
Any help would be appreciated..
Thanks
Old Aug 31, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
Did the handle break or the cable. Is it one or two cables and have you pulled off the trim to expose the underneath part.
Old Sep 1, 2006
TRIZ's Avatar
sounds like that would make ppl think the civic is ghetto. BUMP!!
Old Sep 1, 2006
RHCP0801's Avatar
happened to me and a lot of other members, i still havent fixed mine yet but only the gas door cable broke so i can still open the trunk. I plan on trying to fix it myself eventually, i heard its hard tho
Old Sep 1, 2006
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
join the club, we own 3, and 3 broke, if you open the trunk with your key, pull the carpet back, and youll see where the lock is for the gas cap pin, give the whole thing a turn and it should pop out, and the the door will open
Old Sep 1, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
with mine the trunk latch is stuck. its like its locked in there and yes i tried fiddling with the key hole. i can still push down to open the gas door but when i pull up to open my trunk its stuck, it doesnt go up. i could never figure out the problem.
Old Sep 1, 2006
CraigW's Avatar
^^^ Have you seen this from Honda ?? ----> http://www.geocities.com/pfeifferper...oesNotWork.pdf
These are provided by a member here.
Old Sep 3, 2006
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
u wouldnt happen to have a rear tower bar would u? if u do u might have the cable underneath it preventing it from opening the trunk. i had that happen when i installed my rear tower bar and couldnt open the trunk or gas door. if not i have no clue
Old Sep 7, 2006
ctopher's Avatar
I've got the molding taken off and the carpet pulled back and as far as I can see, There is only one cable going to this lever. How it works I have no idea. Does anyone know of anywhere on the net or on this site that would have specific instructions on how to tackle this cable replacement?
GotSiR
Jun 23, 2016 04:06 PM
Dave1984
Jul 22, 2015 06:10 PM
muttleytm
Jul 11, 2015 06:00 PM
jody501
Jul 10, 2015 11:01 AM
cgavin1
Jul 7, 2015 07:10 AM
