General Post issues, questions that are not in the other sub-forums
OBD2 Communication Error After Belt Broke
Old May 13, 2019
Itsnotmyfault's Avatar
Itsnotmyfault is an unknown quantity at this point
Angry OBD2 Communication Error After Belt Broke
2004 Honda Civic LX , I was backing out of my driveway engine started to act up smoke came up from under hood I pulled back up the driveway shut the engine off open the hood found belt was burnt off The AC pulley froze , got a belt to bypass AC pulley , started engine, Check engine light was on, no response from the RPM gauge no temperature reading green key flashing engine running rough like no power, hooked up ODB ll code reader got connections error check connections I did and still reads the same ODB getting power
Old May 13, 2019
Colin42's Avatar
Re: OBD2 Communication Error After Belt Broke
not a diy, moved, made title more descriptive
check for damaged, broken, melted wiring under the hood that the belt may have damaged, sounds like maybe a ground issue
Old May 13, 2019
Ty, it fried the electronic magnetic, blew the condenser fuse , I replaced the fuse and I disconnected the AC plug-in, still have same issue
Last edited by Itsnotmyfault; May 13, 2019 at 07:33 PM. Reason: I wasn’t done Writing
Old May 13, 2019
Slumpertcivic's Avatar
Unbolt the battery and verify the thick wire going into the alternator didn’t get yanked out of the back of the alternator.
Recheck that both the alternator 12mm mounting bolts are good and tight.
Old May 13, 2019
I bet you didn't tighten all of the alternator bolts.
Doing so can quickly cause permanent damage to the PCM.
Old May 13, 2019
But I did, had to loosen them to replace the belt w/o AC then tighten them back up, then rechecked after started the engine run for few mins then shut off
Niaboc67
Mar 30, 2018 07:44 PM
DRAZO11
ECU Fried
Nov 27, 2013 01:43 PM
JDM for Lyfe
Sep 8, 2012 01:29 PM
Simbashi
Dec 15, 2009 10:34 PM
Slow Gold
Electrical
Feb 19, 2006 10:17 PM
