Poor Acceleration P1298 Code [solved]
Hi, I have a 2001 civic EX MT Em2 civic. I recently bought the car which had bad piston rings so I swapped in a 2005 ex motor. The car had poor acceleration problems before I did the swap and after so I'm kind of just scratching my head trying to figure out what's wrong. The pcm is throwing only a P1298 Code for the ELD and I was wondering if dropping in a new one would fix the acceleration issue.
re: Poor Acceleration P1298 Code [solved]
Not that I can tell. Wouldn't there be a code that comes up if a cat is clogged? There does seem to be an exhaust leak somewhere, possibly before the cat. Checking fuel trim data from OBDII scanner shows negative % data when throttle is applied.
Not necessarily, and if the rings needed to be done then it must've been burning oil pretty bad.
you can either loosen the bolts where the manifold meets the head or remove the primary o2 and see if the acceleration is better
Yeah, the previous engine burnt about 3/4s of a quart of oil within a 37 mile trip home after purchasing it. I replaced the ELD and now have no codes stored or pending, however am still having the acceleration issue. I'll try unbolting the downpipe from the cat to see if there's any performance gain tomorrow.
This is the easiest way so long as you have an oxygen sensor socket handy.
Also, a more technical way, you can purchase an exhuast backflow gauge and see what the reading is. This is what i did to see if exhaust backpressure could explain a lack of power. It can also help isolate where the restriction might be.
However, you mentioned there may be an exhaust leak. This would eliminate backpressure as the cause.
Finally getting back to this thread a month later lol. Turned out to be a clogged cat. Loosened one of the downpipe bolts and I immediately felt an increase in power. Thanks to all of you for giving suggestions to diagnose this. Unfortunately a new cat with downpipe included is $600 since I couldn't source one from any near junkyard, my solution was to just hollow out the cat.
Re: Poor Acceleration P1298 Code
hello_man
Jul 29, 2010 02:27 PM
reject
Jun 22, 2006 12:27 PM
hk2ronin
Oct 19, 2005 08:12 PM
