General Post issues, questions that are not in the other sub-forums
2001-2003 headlight adjustment in california
Old Jan 20, 2019
310civicEX's Avatar
310civicEX is an unknown quantity at this point
I really do not want to pay $60 for something that has got to be easy... does anyone know the steps/guidelines/ perameters I believe I got 2 inch drop springs.
Old Jan 20, 2019
310civicEX's Avatar
Re: 2001-2003 headlight adjustment in california
After posting it showed "related topics" this was #1..://www.civicforums.com/forums/118-lighting/152358-diy-01-03-headlight-aim-adjustment-56k-warning.html from 04..is it the best procedure?
Old Jan 21, 2019
For sure. A towel, masking tape, Phillips screwdriver, a tape measure, and about a half hour behind a Walmart or something is all you need. Really, anywhere with flat ground, at least 40' of clearance and a big, empty wall
basic procedure
• Park 25' from wall as perpendicular to wall as you possibly can using the center of the bulb as the reference for that 25'
• Measure ground to center of bulb.
• Cover one headlight with towel
• On wall, mark [height measurement] - 2" with masking tape, as straight as you can from bulb.
• Use adjumstent screws to fix aim accordingly.
• Repeat procedure with other headlight.
ahailey
Jan 27, 2009 10:32 PM
Seks
Dec 17, 2008 03:27 PM
UofAcivic
Apr 18, 2006 08:16 PM
southwest713
Lighting
Apr 15, 2004 01:32 PM
skc
Canada West
Aug 6, 2002 04:04 PM
