General Post issues, questions that are not in the other sub-forums
LAF sensor P1166
Old Nov 7, 2020
curlywurly's Avatar
curlywurly is an unknown quantity at this point
LAF sensor P1166
2003 Civic Hydrid.
I had a P1166 code, which as I understand it is the LAF (AirFuel/Flow sensor, top of manifold) so purchased a Denso 234-9005 to replace it, the original was a Denso as well. It cleared the P1166 code bit now throws a P0134 code.
Note, car does not have a rough idle, and seems to run fine, might be a little down on power.
The old sensor measure open circuit across the 2 back wires, which I believe are for the heater circuit, the new one measure about 1.17ohms, so seems good.
I think the P1166 is a faulty heater circuit, which validates my reading of open circuit on the old sensor, and the P0134 is now indicating a low or no signal from the new sensor, which is odd, so do I have a faulty sensor?
I think the hybrid has a third O2 sensor on the cat.
Curtman
Jan 11, 2019 03:32 PM
hollyjosh2k3
Jul 28, 2018 09:36 AM
rbeatty
Dec 9, 2012 09:00 AM
hybridhaver2005
Feb 3, 2009 08:21 PM
Dark2k1
Engine Swaps
Mar 29, 2005 12:17 PM
