Squeaking noise on Honda Civic 2001 Lx
About 2 weeks ago I started hearing a squeaking noise on the driver side of my car . It gets worse as I accelerate and stops sometimes when I stop. It stops after awhile when the car just sits still. I have had both belts replaced and the squeaking did not stop . Any ideas ?
Re: Squeaking noise on Honda Civic 2001 Lx
Most likely a/c (belt) tensioner pulley or the alternator. Use an auto-stethoscope or long piece of 1/2" or 3/4" pvc pipe against your ear to listen for suspected parts when engine is running.
I was told that I am missing a nut on the lower alternator tightening screw. Could this be the reason for the squeaking and where can I get the nut from ?
Get that fixed asap...could possibly lead to bigger issue PCM damage. Read: https://honda-tech.com/forums/honda-...-read-3166577/
Don't forget to tighten all the bolts!
Loose alternator mounting bolts can ruin the PCM. That ain't cheap. .
That belt is for the alternator and A/C compressor (if equipped). There is a wingnut on the bracket on the bottom of the alternator used to tighten the belt. Then there are two more bolts on that same bracket to lock it down.
Maxpeedingrods
May 16, 2018 10:09 PM
