- 95 del sol Vtec Dohc
- automatic 95 EG mods??
- Boosted B16 Catch Can Help
- EJ1. K20A or B18C swap?
- B18a1 build tensioner issues
- What's the best heads
- 94 civic ex D16Z6 head upgrade?!?
- ISO d16z6 or d16y8 or 7 castlegar BC
- Need help please
- Dseries to bseries swap
- 93 Honda Civic pure stock race car d15
- To swap or not to swap
- B18B1 Build
- d16zc head on b2 block
- 91 Civic Hatchback 3dr Si, 1.6L (D16A6)
- 1992 project
- B-Series Swap or D-Series rebuild?
- Honda Civic 1.5i LS Vtec 4d Cheap engine modifications
- D16 Build
- Zc engines
- trying to swap my eg hatch non vtec to a vtec
- 93EX Engine Swap Questions...
- B18A1 1994 civic
- need some direction in this forum
- Transmission mounting plate help
- Third gen k-series swap question
- Need help
- Swap
- 1995 Honda Civic Coupe ej1 Swap
- Turbo Multipoint swap
- Nooob in need.
- h22a eg civic will not start
- need advice on engine
- moding air box on a budget
- Forced Induction Help
- 1992 civic lx k20a type r swap
- Engine swap info needed
- B/DSeries EG/Delsol Engine Swap Video Inquiry
- Swap info needed
- GSR Swap help 94 del sol
- need some help with a turbo
- Eg6 Swap Suggestions
- Rwd civic hx
- p28 chip question
- Please help!!
- help: b18a4 starter
- h23a swap in 93 hatch need help
- I need some swap advice
- swap advice
- Hey
- B20z2
- Jdm b18c help!
- 93 civic ex crank, spark and fuel but won't start zc bottom end with d16z6 head
- b16 swapped
- D15B2 swap
- d15 non vtech to vtech conversion....????
- Question on swap
- Z6 head and Y8 head parts swap
- 94 ex w/ sohc vtec
- Turbo help on a 95' dx sedan
- Best Turbo for D16A7?
- turbo help
- Dpfi to mpfi questions
- Idle Issue.
- D15B7 + VTEC head
- PiggyBack Programmer
- Advice on my turbo build
- rwd conversion
- What would you do?
- boosting my d16y8 (a few questions)
- EJ2 and not knowing where to start
- Engine swap
- Engine swap
- b18c
- K20/24 Frankenstein motor
- 1995 LX Turbo Questions
- D16A8 engine help
- D16Y8 swap, please help, new to this :/
- Y is it bubbling and overheating???
- Suggestions on an engine swap?
- best possible engine swap?
- JDM D15B Intake Mani on D16y7???
- H23a1 swap in 93 honda ex coup eg
- b20b valve cover gasket, spark plug seals, piston rings
- boosted b20 or boosted ls
- vtec d series vs b20b
- Timing Question
- D16Y8 swap into 93 eg hatch
- Looking to turbo my d16z6. Need Help!
- answers needed please
- Chassis
- daily driver
- 4speed to 5 speed trans swap help please..
- Engine Swap
- B16b(typeR) or b18c
- Level of Difficulty
- best manual tranny for B swap??
- 1991 civic ex b16a swap
- no turbo xs boost controller for me
- automatic to manual transmission conversion for 1995 gen civic
- Boosting help please
- boosted ls
- 1989 Civic needs new engine
- Bseries Swap
- First swap, plz help
- turbo problem
- 89 civic si hatchback swap b16 to b18 help
- will my 99 civic si ECU work on a ITR engine??
- D16z6 to B16a swap
- turbo question
- noob question-engine swap
- D15B7 to D16Z7 motor/tranny swap question!
- B Series Swap Info??
- Block guard or no?
- Power Wanted
- D15B Vtec swap in an ef
- 91 hatch b18b1 build
- h22a lsd Axles
- In need of a engine ASAP
- B18c for me!
- D15b8 with d7 head build. Where to get pistons and stuff from?
- time to play. please come play.
- New owner, lots of questions!
- Boosted d-series
- D15A1 DIY Engine Rebuild
- del sol vtec swap
- rwd conversion
- b20 block build help
- auto transmission with b18b?
- 94 civic non vtec
- 1995 Honda civic ex d16z6 build
- Poormans swap or b16a
- wanting to know some info on turbo and stuff
- need advice and help
- how to install 440cc injectors in a d15by
- how direct of a swap would this be in a 95 ex sedan?
- nitrous to a D15B7??
- I am new to the site and i need help w/ a b18c1 supercharged
- Hi I'm new to the forum but I was woundering if...
- D15 to D15 vtech engine swap
- swap motors or add a turbo
- D15Z1 swap troubles..help!
- '90 civic hb dohc zc questions
- 1990 HB Civic need help with swap
- Carb to MPFI? (86 CRX)
- d series build basics
- d15b swap in 2000 dx coupe
- CRX engine swap questions
- what to do?
- 1990 civic si engine
- want to do motor swap
- Vtec Swap
- 95 civic sedan vtec swap
- D16 Advice I Want it Faster
- ~~HELP~~ d16 swap to b16 or b18
- 94 Civic EG Swap...NEED HELP
- will a 90 lx 4door transmission fit a zc 1.6 dohc
- Engine Swap question
- looking for complete turbo kit
- no knock sensor plugged in after swap?
- 91 d15b2 swap to zc si harness driver side connector not fitting
- Throttle body gasket for D15B engine
- What to put in a '91 DX
- Turbo'd automatic
- Toyota/Nissan racer needs civic info
- D16 or B18
- d15b2 zc/si head
- D15B7 motor swap and Auto-manual swap worth it?
- To turbo or not to turbo?
- B18c Swap + Ebay Turbo?
- turbo building what one??
- Swap D15B How to?
- 1990 civic hb engine q and a's
- Turbo Help
- 93 CX HB Turbo?
- '94 DX Motor swap advice. Please!
- this is what i am looking at so far, help
- Vacuum Leak?
- d15 to zc
- GSR engine
- cel 9
- turbo any good?
- Swapping woes
- building a N/A B series for nitrous
- 95 Civic Turbo Problems
- D15b1 help
- GSR Or B16?
- d15 to a b16 to put in my de sol
- motor swap help
- 91 honda civic hatch 1.5 engine removal
- 1986 EF SI, what swaps will fit?
- D To B-Series Tranny Swap
- onward with the b18c swap (serious builders only pls)
- Turbo
- d16z6 to d15b7 downgrade
- d16z6 too slow
- vtec or not?
- How to boost an H or F series motor.
- H-Series Engine Specifications, Swap Guides and Faq.
- D-Series Engine and Transmission Specifications..
- B-Series Engine and Transmission Specifications..
- Honda/Acura Engine Codes.
- D16 to GSR Swap HELP
- Turbo or Swap?
- D16Z6, Possible MPFI?
- Can i do it? hatch project
- d15 block/d16head timing?
- d15 turbo, Ready for this?
- Turbocharge D16
- b16 swap 94 civic coupe
- sohc to sohc vtech
- D16Z6 Swapped for a B16(A?)
- Which for motor turbo swap? b16 or b18b1
- 89 crx needs new engine
- 87 wagon D15A2 carb swap?
- What engines can I swap to increase power?
- need info
- New Owner, lots of questions
- no idea if this is a good set up or not
- b18 engine
- ef hatch gsr
- d15b7block/d16y8 head ???s
- B18 swap into EG Hatch
- questions on locked up prelude swap hellpp!?
- Help please 94 civic
- Should I do a swap?
- Custimization for 95 civic engine swap
- engine
- Most popular Civic engine to turbocharge.
- Performance mods!
- Engine swap easy yes or no
- Noobie Mech needing HELP with swap.
- turboing a d15b vtec-e engine
- Type-R Build project
- HELP New To Fourms
- 1.3 to 1.6(b16b) engine swap questions.
- b18 swap
- How to tune up D15b7 engine???
- 89 civic has turbo envy
- 92 civic hatch minime swap. help!!
- swap
- Will it fit??
- B18b LS automatic into D15 DX automatic EG.
- EG to B18b swap AND auto to 5 speed swap. HELP?!
- need help
- New member here, a have a few questions
- Slow to Go in California
- 1994(not 1990) Vtech problem Please Help
- 1990 vtech engine problems HELP Please
