Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
I need some swap advice
Old Aug 9, 2015
OldschoolCool's Avatar
OldschoolCool is an unknown quantity at this point
What's up peeps. I have a 87 hatch and I want to do a LS swap. Anyone ever done a swap like it, or know where I can find some info on if it can even be done without cutting up the car? Thanks
Old Aug 10, 2015
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: I need some swap advice
You want to convert a FWD 4cyl car to RWD v8 without cutting anything up? May I please have whatever you are smoking good sir?
Old Aug 10, 2015
Bahaha not a V8 LS, a B18 out of an LS teg. Obviously you have no useful info.
Old Aug 10, 2015
mcnoople's Avatar
Sorry, anytime I see LS listed as an engine I will always assume it to be the GM LS series of engines. It is 1 of the most commonly swapped engines. Plus with a user name of oldschoolcool I assumed you to be the kind that liked old american gas guzzling iron. LS is not an honda engine it is as you said a B18. Had you said a b18 I never would had said a word. I used to see threads of this nature on another board I used to frequent, only they did intend to swap v8's into anything and everything because some people really do think that way.
sorry for mistaking your intent and good luck with the swapping.
Old Aug 10, 2015
Hasport makes motor mounts so you can basically drop in X engine into Y's engine bay.
Here's their mounts to drop in a B-series (hydraulic transmission) into an 84-87 civic
Or if you decide on a cable transmission
Both are $400. As far as other components you'd need, I'm not too sure.
Old Aug 10, 2015
LOL, The first thing came to my mind was an V8 too - civette!
Old Aug 17, 2015
Thanks for the help RiceBoy!!
soufigured
15
Aug 18, 2015 08:22 PM
Farticle69
Aug 6, 2015 08:02 PM
JKWood
Jul 28, 2015 03:45 PM
Kyle Cargazm
Jul 16, 2015 02:06 PM
